Slightly new twist on fitting to dadoes? - Router Forums
 7Likes
post #1 of 11 (permalink) Old 06-24-2016, 11:27 PM Thread Starter
Default Slightly new twist on fitting to dadoes?
I needed to make a set of louvers to install in a gable end as a vent the other night and needed to get it done quickly. I got the idea to use my dado set for the grooves but setting them to the exact width of the boards can take a lot of time that I didn't want to spend. So I came up with the idea to just set the stack for some random width less than the total thickness of my boards and then rabbet the ends of the boards to fit. The boards were about 3/4 thick (never bothered measuring) so I put together a stack about 1/2" thick (also didn't bother measuring).
I decided that 60* would be an reasonable angle for the slats so that way I could use the fence to set the distance from the ends of the uprights for each slat and the miter gauge for the angles. Since each side has to be the mirror image of the other by picking an easy angle on the gauge I could flip the miter gauge back and forth from left to right for each side without moving the fence and without an angular error.
Once the dadoes were done I took the slats and stood them on end against the table saw fence and nibbled away at the first slat doing one side and then flipping it around and cutting the other side. After about 3 or 4 nudges of the fence closer to the blade and I had the fit right so I milled all the ends that way.
Because I used the dado stack to cut both the dadoes and the rabbets the depth of the grooves was the same as the width of the rabbets so that issue took care of itself. From concept to finished product took less than two hours with a set of glued and brad nailed louvers.
I found this way to be much, much faster than trying to fit the full sized board ends to a full sized dado.
DaninVan, Gaffboat, Nickp and 2 others like this.
post #2 of 11 (permalink) Old 06-24-2016, 11:38 PM
Excellent thinking Charles...
post #3 of 11 (permalink) Old 06-24-2016, 11:41 PM
but why didn't rip a face angle...
no weather exposure to speak of???
post #4 of 11 (permalink) Old 06-25-2016, 07:42 AM
Gaffboat's Avatar
First Name: Oliver
A great, practical, time saving idea, Charles. I like it.
Gaffboat is offline
post #5 of 11 (permalink) Old 06-25-2016, 08:29 AM
First Name: Richard
Necessity being the mother of invention shows up again. Nice idea, good work.
Shop guy is offline
post #6 of 11 (permalink) Old 06-25-2016, 09:07 AM Thread Starter
No. It will go just under the peak under about a 2' overhang so it shouldn't get much weather. I still have to add a face frame to it to trim around the opening and I'll make the unit removable so I have a better access into the attic. That won't take long to do. One corner will only be about 4" above the carport roof.
Thanks to everyone for the compliments.
post #7 of 11 (permalink) Old 06-25-2016, 09:19 AM
hawkeye10's Avatar
First Name: Don
Chuck this shows you are smart and the reason you are a "Moderator".
Cherryville Chuck likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #8 of 11 (permalink) Old 06-25-2016, 09:40 AM Thread Starter
They made me a Mod because I was too stupid to say NO.
DaninVan likes this.
post #9 of 11 (permalink) Old 06-25-2016, 11:20 AM
Nickp's Avatar
First Name: Nick
No tool should be single-purpose...nice idea...
Nick
Nickp is online now
post #10 of 11 (permalink) Old 06-26-2016, 12:07 PM
BowlBit's Avatar
First Name: Dave
Great thinking. I made a dado board with my dado set and use it to get close, and now, I will rabbet to the finished size. Will definitely speed things up even more.
BowlBit is offline
Advice needed with Air hose fitting replacement vindaloo Tools and Woodworking 29 09-09-2013 09:05 PM
Barley Twist Routing Project classicsparrow General Routing 8 06-10-2011 10:29 AM
Barley Twist Router Bits bobj3 Jigs and Fixtures 3 10-25-2010 09:45 AM
Is there quick fix for slightly loose fitting raised panels? tpyke General Routing 4 06-16-2010 07:12 PM
Best Router Jig For Shelf Dadoes jgagnard Jigs and Fixtures 1 03-31-2009 02:36 AM
