Warped wooden frame. - Router Forums
 6Likes
post #1 of 14 (permalink) Old 07-20-2016, 05:16 PM Thread Starter
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Default Warped wooden frame.
I have recovered a wooden frame from my scrap bin but it is warped to such extend that there is a big gap at one corner. I am afraid that the 3mm glass I want to use for a picture will be broken due to this deformation. I have made some google search but I want to know your opinion on how to repair this defect.
Some pictures showing the problem are attached. Any advice as how to rectify this problem will be highly appreciated. Thank you in advance.
We, woodworkers are everywhere!!!
papasombre is offline
post #2 of 14 (permalink) Old 07-20-2016, 06:07 PM
Plan ''A''...
make a new one...
Plan ''B''...
heat the joints and disassemble...
reglue flat...
if the joints show as opens leave them...
opens can be filled or inlaid w/ an accent to make them look good...
plan ''C''...
heavily saw kerf the back of the frame on the one stile that's to right (turned up) in the pic and both rails...
recommend the kerf depth cut at about 75~80% of the thickness of the wood...
and about 1/8'' apart...
wet the frame and clamp it flat and let it set for a day or so...
if it still lifts in the one corner re-wet and clamp it so the high corner is at negative coplaner...
after you get to happiness flip it backside up and fill the kerfs w/ Rock Hard...
Plan ''D''...
after disassembly if any of the rails or stiles are misshaped in any way or foem...
scrap them and make new ones or try the kerfing method to bring them back into line...
NOTES...
FWIW cross grain kerfing will get that to lay flat...
you will still have to to fill the kerfs...
you will have to edge band the edges either with stock or veneer to hide the kerfing..
when you fill the kerfs make sure the frame is clamped flat...
cross grain kerfs need to be about 3/16'' apart...
if you opt to cross grain kerf start just before where the stile rises up and stop kerfing when it goes flat.....
DO NOT rely on the glass to do anything for the frame...
edge band before you fill the kerfs...
Nickp and Herb Stoops like this.
post #3 of 14 (permalink) Old 07-21-2016, 08:04 AM
First Name: Frank
papasombre, I really enjoy this message. I have the same question. I have a picture that is in an old very old oval frame. It is of my grandmother as a young woman. I am sure you have all seen old pictures like this. The frame looks like it has been in the left in the sun for a long period of time. I have been afraid to do much with because of the glass in it. I am not sure if you can even replace the glass in it. It is a frame made, I think in the early part of the last century or even earlier than that. I think her father made the frame and may have taken the picture.
At any rate, I appreciate the comments and help here from the forum.
Tagwatts1 from Utah
Remember to eat your desert first as you may die before your food arrives.
Tagwatts1 is online now
post #4 of 14 (permalink) Old 07-21-2016, 10:10 AM
Country: South Africa
First Name: Paul
Remove any finish to bare wood. Soak in bath for an 1hr and then clamp flat. Leave for a few days to dry. Sorted.
I've been doing some experiments recently bending wood around a form using this method. Works like a charm.
Hard woods need a longer soak time.
Cheers
Paul
PaulH is offline
post #5 of 14 (permalink) Old 07-21-2016, 11:44 AM
First Name: Richard
I agree with Stick wholeheartedly. My first choice would be his Plan A. Less time and less hassle.
neville9999 and Semipro like this.
Shop guy is offline
post #6 of 14 (permalink) Old 07-21-2016, 12:15 PM
Cheers
Paul
works well on woods that aren't kiln dried...
post #7 of 14 (permalink) Old 07-26-2016, 12:58 PM Thread Starter
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Thank you all, guys.
I'll try plan A as mentioned by Stick but, since i have kept this frame for long time I will try some of the methods you have mentioned. I will learn something new from this situation.
paduke and DesertRatTom like this.
post #8 of 14 (permalink) Old 07-27-2016, 01:12 AM
Country: Thailand
First Name: Ja
goods
Ija Mawa is offline
post #9 of 14 (permalink) Old 11-04-2016, 01:34 AM
Going for a new one would be a better option
SusanneX16 is offline
post #10 of 14 (permalink) Old 11-04-2016, 10:41 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Frank, glass wont bend especially if its old. If the glass is not broken then you can be sure the frame is not connected to the glass very securely.
You can remove all backing layers and get the photo out. The glass will just be laid into a rebate around the edge of the frame.
What you do to the frame is up to you, but unless there is significant financial value to it, its easier to make a new frame and get new glass cut to suit.
sunnybob is online now
Fabric Art with Arts & Craft Walnut Frame TRN_Diesel Show N' Tell 15 07-28-2014 08:55 PM
How to Make a Decorative Picture Frame Using a Router learnexperience Tools and Woodworking 1 08-02-2011 11:47 PM
Creating a 'trench' in a wooden frame jf1 Starting Off 14 11-09-2008 08:04 PM
