Online Assymetric Cove Templates - Router Forums
post #1 of 2 (permalink) Old 01-30-2013, 12:39 PM Thread Starter
MAFoElffen's Avatar
Default Online Assymetric Cove Templates
Awhile a go, I posted a few questions about calculating Asymmetric Coves. Review is a Symmetric Cove cut on a table saw is when you have a fence at an angle to the blade and pass your work piece over it (stepping the depth of cut in increments), resulting in a cove cut that is the same on both sides. An asymmetric cove is when you have a fence at an angle and bevel the blade, then pass your work over it (again the depth of cut in increments), resulting in a cove than varies in curve from side to side.
At that time, I didn't find an online calculator, so I cut out samples to try to match various angles and bevels. This method was a pain.
Last night I found an online calculator, that prints out templates and has easy instruction on how to use:
Asymmetric cove template generator
Be aware that the template page uses "Flash." If you load the page and the fields are blank, make sure you have flash loaded or just try using a different browser. It doesn't seem to like the 64bit Linux version of Google Chrome's 64bit flash. It likes Firefox. Don't know about others.
Follow the instructions on that page for how to generate templates. Follow the link from there for instructions on how to use the templates.
MAFoElffen is offline
post #2 of 2 (permalink) Old 01-31-2013, 08:17 AM
OPG3's Avatar
First Name: Otis
COOL! Thanks Mike for posting that! That (as you know) may come-in handy on "our project" - I will pass-it-on to our machinist, Terry Pulliam. I am unaware if he already has such a thing - but it never hurts to "reinforce".
Otis
OPG3
Tweak everything!
OPG3 is offline
Ate the end of my finger off OOPS! jbander Shop Safety 24 12-31-2012 07:55 PM
Shop class Accident in Florida Dmeadows Shop Safety 13 10-09-2012 09:05 AM
how do you START the safety issue ??? Dimitri M Shop Safety 49 07-23-2012 08:40 AM
Table Saw and Router Table Kickback CharleyL Shop Safety 4 02-18-2012 02:22 PM
