Circular Saw Blade SFPM Calculator - Router Forums
post #1 of 3 (permalink) Old 12-17-2013, 08:08 AM Thread Starter
MAFoElffen's Avatar
Default Circular Saw Blade Calculators
Once up a time, I was told that cutting on a circular saw (specifically a table saw) should be done withe the speed at between 10, 000 to 18, 000 surface feet per minute (sfpm). I thought these were important numbers for blade life and quality of cut... until I figured out that some smaller saws are slower that that new. (Ask me if you want those and I'll post.)
Here is an online calculator to find and work with various data for circular saw blades:
Circular Saw Feeds & Speeds Calculator
Then I found a few more:
Circular Saw Calculator, Quad Sawbox, Twin, Feed Speed, Horsepower, Tooth Bite, Gullet Fill, Sawmill - Online Expos
Circular Saw Horsepower Calculator!
Note-- please realize that the blade motor RPM, is not the arbor RPM... unless the pulleys between them are the saem size, 1:1. Usually, they are different in size.
Actually, I found these while looking for something to figure out the feed rate of... which should use the rpm, diameter, teeth per, gullet area... which then would affect depth of cut... and feed rate. Still looking for those formulas, which should be available for CNC TS'es...Rip, Edger and Gang saws. What I've found so far on that is something like this:
Feed speed
The feed speed V, [m/min] is the speed of the forward feed movement of the workpiece or of the tool. The feed speed is proportional to the feed per tooth fz and is essentially responsible for the quantitative output. It is calculated by the formula: Vf = fz n z/1000 [m/min]
where-
Vf = Feed speed [m/min]
fz = Feed per tooth [mm]
n = Revolutions per minute [min 1]
z = Number of cutting edges/teeth
When machining solid wood feed speeds range from 1 – 220 m/min (3.3 - 723 ft/min) with a highest frequency of occurrence in the range 5 – 25 m/min. (16 - 82 ft/min.) High feed speeds require large technical expenditure on tool construction, machine design, workpiece guidance, power demand etc... But there's another one out there that takes into consideration how much waste the gullet has to carry away and the chip load of the teeth on various density materials...
MAFoElffen is offline
post #2 of 3 (permalink) Old 12-18-2013, 08:23 AM
OPG3's Avatar
First Name: Otis
Mikey,
I guess that ever since my age 8, our Dad drilled into our heads (David & me) that 60 mph = 88 feet per second. Much can be done with that. Turning threaded rods with knowledge of their respective TPI and thus measuring nut progression over exactly a minute or fraction thereof can often waken one [user] to the FACT that their tools frequently are not really turning the RPMs stated by the equipment.
Example: When people buy a new car or truck and change-up to a larger wheel/tire size combination - they are no longer going the speed indicated on their speedometer.
OPG3
Tweak everything!
OPG3 is offline
post #3 of 3 (permalink) Old 12-18-2013, 02:24 PM
Mike, Logging and Sawmilling Journal had a sawmill calculation in a center pullout a few years ago that may have the missing calculations regarding gullet size/feed rate you are looking for.
Back in the late 80s someone from the the Riverside Forest Products mill in Lumby, BC told me that they were sawing at about 5.5' per second. They said that he sawyer would get pissed off with the guy running the log bucking station if he was leaving gaps between the logs going into the head saw (probably more like a canter head).
Freud glue line rip blade troubles - table saw phillipdanbury Tools and Woodworking 5 08-25-2013 09:19 PM
Table Saw Blade Sure Isn't Fl;at Jerry Bowen New Member Introductions 6 05-14-2012 10:08 AM
What do you use to sand the edge of plywood? volunteers Tools and Woodworking 8 04-29-2012 10:28 PM
Question about saw blades. N'awlins77 Tools and Woodworking 21 03-21-2011 07:47 PM
Circular Saw Blade RJM60 Tools and Woodworking 11 11-10-2010 12:11 AM
