Router metric bearing replaced with English bearing. - Router Forums
 16Likes
  • 3 Post By Stick486
  • 2 Post By Nickp
  • 2 Post By swarfmaker
  • 5 Post By Cherryville Chuck
  • 4 Post By Kuh Shise
post #1 of 9 (permalink) Old 09-11-2020, 01:06 AM Thread Starter
Default metric bearing replaced with English bearing.
Can anyone advise if it is possible to replace an 8 mm ID bearing with an American bearing with a 5/16" ID ? Is the 0.0025" larger ID close enough to prevent vibration.
Kuh Shise is offline
post #2 of 9 (permalink) Old 09-11-2020, 02:53 AM
on or to what???
Stick486 is offline
post #3 of 9 (permalink) Old 09-11-2020, 07:18 AM
Nickp's Avatar
First Name: Nick
To an 8mm shaft .0025 is a lot of space. It also depends on the RPM's required of the bearing.
8mm ID bearings are readily available in many different sizes and types. I did a quick search for "8mm ID bearing" and got back many sources.
If you can provide some additional info, like Stick asked, maybe we can help you locate the right bearing...
Nick
Nickp is offline
post #4 of 9 (permalink) Old 09-11-2020, 08:44 AM
Country: South Africa
First Name: Ronald
Just to be clear, 8mm is 0,31496 inch, thus slightly larger than 5/16 or 0.3125". If you succeed in pressing an 8mm shaft into a 5.6" bearing without bending or breaking , the bearing inner will most likely crack.
Ronald
Mistakes are proof that I am trying....
Now to remember what!
swarfmaker is offline
post #5 of 9 (permalink) Old 09-11-2020, 12:46 PM
Metric bearings are probably more common now than SAE ones. Any bearing supplier will have or be able to get the right one for you.
post #6 of 9 (permalink) Old 09-16-2020, 12:40 AM Thread Starter
Well, I tried to reply to Stick and Nick, but it did not appear here in the thread. Making a wall cabinet with raised panel doors, and using a set of rail & style cutting bits with top bearings. Straight portions are not a problem as the fence on the router table allows for incremental stock removal until the last pass against the bearing for finish depth. The problem comes with using several passes to remove stock in the arch top rail (Cathedral style) using hand feed. Plan was to begin with a 1 1/4" O.D. top bearing and then step down to reduce the stock removal per pass. Next to last pass made with the original supplied bearing, but with several layers of tape on the bearing. Last pass - remove the tape and run rapidly to prevent burn marks. I checked the top shaft on the bit and it measures 0.3105" so the ASME size will fit (should). Went to my local bearing supply house, looking for metric mearings that might work. Quote was $ 90.00 per bearing. Found some on line, (under 10 bucks) but was concerned that switching between metric and English might create a problem. I guess I did not think through the problem quite enough, or I would have realized that the metric actually had the larger I.D. Just for my enlightenment, should I run into a problem with excess clearance, can one use motor bearing shims ( 0.0030, 0.0050, 0.010 and cut strips as fillers on the inside of a mismatched I.D. and still get good results ??
post #7 of 9 (permalink) Old 09-16-2020, 10:28 AM
I thought you were talking about a bearing on the router and not a bearing on a bit. Check with the major manufacturers and on Lee Valley's website. They all have bearings listed that show I.D. and O.D. You can alter a lot of profiles by changing a bearing. For example a round over bit with a smaller bearing will give you a rounded edge with two fillets with the height adjusted properly. You cam get laminate trim bits with oversize bearings to trim too much laminate overhang down before trimming to proper size with the correct bearing on. (They call them overhang bits. Laminate tends to chip if it has too much overhang.) So it's common to use different bearing sizes but the ID of the bearing MUST match the the size of the bit where the bearing mounts on.
There also rub collars that can go over your bearings that can change the depth of cut. Here's an example from Woodcraft: https://www.woodcraft.com/search?q=b...&button=search I have a set of 4 out in my shop like them. Then there is also this set of bearing/collars from Infinity Tools that fit the very common 3/16" post size on router bits: https://www.infinitytools.com/16-pc-...bit-bearing-ki
post #8 of 9 (permalink) Old 09-16-2020, 07:25 PM Thread Starter
Was able to run the arched portion of the top rail with an "English" bearing with a 5/16 I.D. and a 1 3/8" O.D. successfully. Did a dry fit of the panel, rails and styles to check dimensions. Picture of the oversize bearing and the assembled door. Sorry, the phone doesn't always stay clear and focused.
post #9 of 9 (permalink) Old 09-17-2020, 08:51 PM
Nicely done, Bill!
DaninVan is offline
