5 Basic Clamps for Every Woodworking Shop - Page 2 - Router Forums
 31Likes
post #11 of 17 (permalink) Old 04-27-2017, 12:40 PM
JFPNCM's Avatar
First Name: Jon
Don't forget plain old painter's tape and web belts. Great for rolling up boxes and odd shapes.
Cherryville Chuck likes this.
Jon
JFPNCM is offline
post #12 of 17 (permalink) Old 04-27-2017, 02:23 PM
Actually the Workmate you show is a type of clamp too, either squeezing something between the two halves or using dogs with the dog holes in the tops. They can be very handy at times. I've used mine many times to hold boards so that I can do some free hand routing.
Exactly, and I've used it like that a lot, particularly for trimming the edge banding on drawer fronts and so on. At least until I figured out that it was easier, and quicker, to set up the fence on the router table and do it there. Plus you're not balancing the trimmer on top of a 3/4" wide surface - although I've done that often enough that it's second nature. And maybe I'll try trimming the laminate on the table nest time too.
tomp913 is online now
post #13 of 17 (permalink) Old 04-27-2017, 04:02 PM
Bushwhacker's Avatar
First Name: David
I should be good to go, I have every clamp mentioned, but like pillows. you never have too many.
JFPNCM and Cherryville Chuck like this.
When the enemy is in range, so are you.
Bushwhacker is offline
post #14 of 17 (permalink) Old 04-27-2017, 06:01 PM
First Name: Larry
I like the old tools, clamps included. That doesn't mean I don't have the newer clamps, I just like picking up the older ones when I see them.
The first is a 3-way edge clamp. The second I don't have a name for, they cost me a buck apeice. They may work in a C-Rail or just a hole drilled in a bench with a longer bolt.
Do a Google for 'woodworking clamps' and you will see many! If your Google has the options, click on 'Homemade' and you may find some thing to make.
snoopy55 is offline
post #15 of 17 (permalink) Old 04-27-2017, 06:57 PM
Hi Larry and welcome. That second one is definitely a hold down type clamp. Because of the relatively short bolt in it I would say it was bolted to something metallic.
post #16 of 17 (permalink) Old 04-27-2017, 07:00 PM
I just did a bunch of banding trimming Tom. I took my entire fence and set it on a strip of plywood. I never thought of just using one narrow fence on the infeed side. Good idea.
post #17 of 17 (permalink) Old 05-06-2017, 12:01 AM
I bought eight Harbor Fraight 60 inch aluminum shaft clamps as in the pix below. Although I like them, they're just too big for my little shop, so I've decided to cut them down to shorter lengths. I'll use a fat wedge to keep the ends from distorting as I cut them, then drill a 1/4 hole in the end an put a bolt through to stop off the end. A little lesson for me, bigger (longer) is not necessarily better. I also have a set of Jet parallel clamps that I really love using. The little lever is a quick release, a really nice feature. Wax the shafts when using for glue ups. No fun scraping glue off.
Name:	H aluminum clamps.jpg
Name:	Jet parallel clamp.jpg
197761 likes this.
DesertRatTom is online now
new to all this! mapwd1702 New Member Introductions 23 06-06-2016 11:24 AM
Are 1/4" routers ok? Learningtorpute General Routing 26 05-30-2016 11:48 AM
New member from Upper Michigan chiefifd32 New Member Introductions 23 05-24-2016 09:11 AM
Hello bialy100k New Member Introductions 9 05-23-2016 10:31 PM
Newbie, needs advice bobadkinsfoto New Member Introductions 13 04-22-2015 01:50 AM
You may not post new threads
