Considering Designing Your Own Tool Storage System? - Page 2 - Router Forums
 46Likes
post #11 of 36 (permalink) Old 05-11-2017, 11:22 PM
roofner's Avatar
First Name: Gary
If you have seen the latest family handyman magazine. They have and interesting new design for small shops a mobile tool storage unit. The unit is dubbed the supper storage cart. There design uses a two dimensional look. If you look at one side view and go around the other side a different look. If I were building mine would be one dimensional . Mine would be like the side with left having upper shelves and on bottom drawers similar to a craftsman roll around and other half would have drill organizer and charger station at the top and shelves below that. Here is the cover picture of storage cart.http://www.ebook3000.com/The-Family-...17_436879.html
roofner is offline
post #12 of 36 (permalink) Old 05-12-2017, 02:02 AM
RainMan 2.0's Avatar
Originally Posted by roofner View Post
If you have seen the latest family handyman magazine. They have and interesting new design for small shops a mobile tool storage unit. The unit is dubbed the supper storage cart. There design uses a two dimensional look. If you look at one side view and go around the other side a different look. If I were building mine would be one dimensional . Mine would be like the side with left having upper shelves and on bottom drawers similar to a craftsman roll around and other half would have drill organizer and charger station at the top and shelves below that. Here is the cover picture of storage cart.The Family Handyman - May 2017 - Free eBooks Download
Thanks Gary , as that's an idea I never thought of !
I've been trying to figure out where I'm going to find a spot to put my drill/air nailer storage system that I built in the future .
Seeing this mobile stand is just the ticket imo. I can integrate my system right into it
Ok ,I never insulate
RainMan 2.0 is offline
post #13 of 36 (permalink) Old 05-12-2017, 07:39 AM
That's similar to my cabinet, but on a much larger scale. It was fine way back when I first built it, but became awkward to use once I started adding to the shop and lost the open space I once had. It now sits basically in the same spot, moves slightly side-to-side to give access to either the drill press or jointer, and I wind up walking across the shop to get the tools stored in it.
tomp913 is offline
post #14 of 36 (permalink) Old 05-12-2017, 11:40 AM
I can see that happening, but I don't think I have a choice . Guess it will depend on how many big machines will have mobile stands on them .
I gots to win the lottory and get my 40'x60' shop built and be done with it . While I'm at it , a paint booth would be kinda handy to
TenGees likes this.
post #15 of 36 (permalink) Old 05-15-2017, 09:19 PM
MT Stringer's Avatar
The cabinets I built have worked well. They are hung on French cleats and screwed to the wall studs just for insurance. Almost everything I need, and use most often, is right at hand.
MT Stringer is offline
post #16 of 36 (permalink) Old 05-15-2017, 09:48 PM
I love that setup Mike . I need to add sections onto mine , as I'm really liking those clear storage drawers underneath.
post #17 of 36 (permalink) Old 05-15-2017, 11:11 PM
kp91's Avatar
First Name: Doug
I like them too, you get to keep everything sorted and organized, until you drop one... and that isn't second hand information.
Of course I dropped a 1000 ct box of kreg screws the other day, lucky for me only 100 spilled out.
Great looking cabinets, Mike!
MT Stringer likes this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #18 of 36 (permalink) Old 05-16-2017, 12:37 AM
If you decide to use plastic storage trays as drawers, be sure you buy a lot at the same time. Retailers are notorious for changing brands that don't match your system.
Mike, that is a wonderful storage unit. I like that the battery chargers are right there too. Painting just adds that extra touch, and probably makes it easier to remove the ever-present sawdust.
kp91, Gaffboat and MT Stringer like this.
DesertRatTom is online now
post #19 of 36 (permalink) Old 05-16-2017, 09:24 AM
CharleyL's Avatar
First Name: Charley
It always amazes me how many woodworkers use so much wall space to hang their clamps side by side.
In my small shop I don't have that much wall space, but have a lot of clamps.
Using 2 by stock ( 2 X 4, 2 X 6, etc.) I made what looks like heavy duty shelf brackets of different widths, and attached them to the wall with spaces between them just wide enough to allow clearance between them for the pipes or bars of the clamps. I now stack up to 10 of each length of bar or pipe clamp between these heavy duty shelf brackets. A different slot is used for each length of clamp.
The brackets vary in width depending on how big the head of the clamps are, and so the adjacent rows of clamps have enough space for the clamp heads. I made a kind of "French Cleat" by mounting a 2 X 4 to the wall with lag bolts and I hook the heavy duty shelf brackets in position along this 2 X 4, spaced so the pipe or bars of the clamps will fit between them, then drive a large screw through the bracket and into the 2 X 4 to make certain that it doesn't move. Clamps that are stacked outward from the wall in this density are "Very Heavy", so a strong wall and attachment system is extremely important.
I now have over 50 bar and pipe clamps hanging from my shop wall in a wall space that most woodworkers have 6 or 8 clamps stored. Small shops require dense storage, especially when it comes to using wall space. I now have the 2 X 3 "French Cleats running all the way around my shop walls at several levels and the mating piece attached to my cabinets, parts bins, etc. So it's easy to rearrange almost everything on the walls whenever I want to, but I do add screws to secure the heavier items, so there is no chance of them moving or falling if they should ever get "bumped".
Charley
tomp913 likes this.
Central North Carolina
CharleyL is offline
post #20 of 36 (permalink) Old 05-16-2017, 10:07 AM
roofner's Avatar
First Name: Gary
I need everything on wheels no room. I need my radial arm gone.
RainMan 2.0 likes this.
roofner is offline
peak hp vs. real hp danapointed New Member Introductions 15 05-10-2017 04:33 PM
Craftsman v. Delta Tablesaws Thowie70 Tools and Woodworking 22 02-24-2014 11:12 PM
How to build clam shell tool storage boxes Web Shepherd Jigs and Fixtures 13 01-07-2013 06:07 AM
Update On Dust Right System Jerry Bowen Tools and Woodworking 2 07-18-2012 01:15 PM
Feeds & Speeds LMT Onsrud (Onsrud) Router Bits - Types and Usage 0 02-12-2012 03:51 PM
You may not post new threads
