Tips for Working with Jigs - Router Forums
 44Likes
post #1 of 18 (permalink) Old 07-11-2017, 10:58 AM Thread Starter
Administrator
Router Forums's Avatar
Default Tips for Working with Jigs
Every woodworker wants his or her time in their shop to be efficient and productive. Some of the most important tools in the shop are the jigs used to help make your work cleaner and easier. Jigs are physical versions of workshop shortcuts, tips and workarounds that can actually make a job fast and fun, although they won’t necessarily give you the precision and skills you might not yet have. Working with Jigs
Read more here:
http://www.routerforums.com/articles...ing-with-jigs/
Cordyline likes this.
Follow Router Forums on Facebook
www.facebook.com/RouterForums
Router Forums is offline
post #2 of 18 (permalink) Old 07-11-2017, 01:22 PM
JOAT's Avatar
First Name: Theo
I make my own jigs or whatever, partly because it's more fun that way, and partly because that way I get exactly what I want, not what someone else thinks I want.
Call me a craftsman, artisan, or artistic, and I will accept that. Call me an artist and you will likely get a quite rude comment in return. I am not a @#$%ing artist.
JOAT is offline
post #3 of 18 (permalink) Old 07-11-2017, 01:51 PM
Gaffboat's Avatar
First Name: Oliver
Shop-made jigs are always important for my projects because I can fairly quickly cobble something up that will ensure control, enhance repeatability, or extract complex operations into multiple simple steps. I have also learned to write a note on the jig with its purpose and date. Otherwise after a few months I look at it and think "What the heck did I make this for?"
kp91, TWheels, Wildwood and 6 others like this.
Gaffboat is offline
post #4 of 18 (permalink) Old 07-11-2017, 04:46 PM
One of my favorite jigs is one for making splines in picture frames. It has a sliding fence that's tall so I can clamp on a picture frame. Because the V angle is exactly 90, I can place a backer on the back stop, to prevent chipout when using my 1/4-3/8ths specialty blade. That increases the versatility. The fence cinches down tight and can be set to place the spline precidely every time. It is close to 18 inches wide.
Name:	spline jig 1.jpg
Name:	spline jig 2.jpg
JFPNCM, billyjim, TenGees and 3 others like this.
post #5 of 18 (permalink) Old 07-12-2017, 11:33 AM
TenGees's Avatar
First Name: Paul
Originally Posted by DesertRatTom View Post
One of my favorite jigs is one for making splines in picture frames...
I slapped something similar together to make a simple frame for a mirror. I've used it several times now. After seeing yours, Tom, I won't be posting pictures of mine.
TenGees is offline
post #6 of 18 (permalink) Old 07-12-2017, 12:15 PM
First Name: Ellery
When it is feasible I make my own jigs. Some custom to my equipment, some for a specific project. I try to make a specific project jig universal for other tasks, if possible.
Sometimes the jig is more satisfying than the project.
An update: I have moved, still have not set up my new shop yet. No woodworking this year. I hope to change that soon.
Ellery Becnel
Roy Drake likes this.
Arcola60 is offline
post #7 of 18 (permalink) Old 07-12-2017, 02:22 PM
JOAT's Avatar
First Name: Theo
Or, just as bad, when you're making multiples, with no writing sometimes it will wind up in whatever you''re making. Then it's remake time. Now the first thing I write on mine is MASTER, on each side. Don't ask how I know this. I write anything useful on mine, how many copies I will need, etc.
kp91, Gaffboat and Roy Drake like this.
JOAT is offline
post #8 of 18 (permalink) Old 07-12-2017, 03:33 PM
kp91's Avatar
First Name: Doug
I will echo the putting of notes on jigs. What bit to use, etc are all hard to remember after a while
Shop guy likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #9 of 18 (permalink) Old 07-13-2017, 12:01 PM
JFPNCM's Avatar
First Name: Jon
@DesertRatTom
That jig should work very well for adding splines to the corners on boxes.
DesertRatTom likes this.
Jon
JFPNCM is offline
post #10 of 18 (permalink) Old 07-13-2017, 04:15 PM
vindaloo's Avatar
First Name: Angie
Thumbs up So timely
Oooh, glad I stopped by this thread. I'm just putting together a photo storage box and it is to have splines. I knew I'd seen one somewhere but couldn't remember the original thread, now here it is. Thanks Tom, so timely.
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
Oak Park spacer (box) jigs jw2170 Jigs and Fixtures 9 07-29-2013 09:08 PM
jigs from aluminum? meanbee Jigs and Fixtures 13 01-22-2013 06:31 AM
You may not post new threads
