Tips for Installing a Dust Collection System - Router Forums
 88Likes
post #1 of 122 (permalink) Old 06-25-2015, 05:55 PM Thread Starter
Administrator
Router Forums's Avatar
Default Tips for Installing a Dust Collection System
There's no way around it: wood dust is a health hazard. Multiple health agencies have classified wood dust as a carcinogen. As a woodworker, whether professionally or as a hobbyist, safety should be the top priority -- even ahead of creating a quality product. This is where dust collection systems come in - the name is pretty straightforward for their purpose: they collect the dust that can harm your lungs and cause health problems later down the road. Dust Collection
Read more here:
http://www.routerforums.com/articles...ection-system/
Follow Router Forums on Facebook
www.facebook.com/RouterForums
Router Forums is offline
post #2 of 122 (permalink) Old 06-25-2015, 05:57 PM
Administrator
Cricket's Avatar
First Name: Cricket
Feel free to respond with effective methods that you have found for dust collection or anything you would do differently.
Share pictures of your dust collection system!
epurcell likes this.
Need admin assistance? Post here so we can help you!
Cricket is offline
post #3 of 122 (permalink) Old 06-25-2015, 06:07 PM
RainMan 2.0's Avatar
This is perfect timing as I recently added a sander and relocated my dust collector . I need to find out which way would be best to plump the machinery . I'm assuming 4" ABS and waste gates but I'll post a pic and see what the experts have to say
Cricket likes this.
Ok ,I never insulate
RainMan 2.0 is offline
post #4 of 122 (permalink) Old 06-25-2015, 06:50 PM
First Name: JT (Jim)
While the plastic duct system is more air tight (less leakage) it has the highest chances of sustaining static. Plastic dust must have a good grounding system attached to every foot of it. Inside the plastic ducting is the most efficient. I used metal ducting to eliminate the need for a ground wire along the entire length of the system. Beside the ground wire from the motor to the electric supply I have an external ground from the dust collector to the grounding rod that is used for the electric panel located outside the building. Being an ex USCG Damage Control (Fire Fighter) I cannot be safe enough from fire hazard, especially when we were out at sea.
Cricket and Professorss like this.
subtleaccents is offline
post #5 of 122 (permalink) Old 06-25-2015, 07:04 PM
JT; I'd be very surprised if putting the Copper ground wire on the outside of the PVC piping would be effective. My understanding was that it needed to be on the interior where of course it brings up other problems.
JFPNCM, Cricket and Professorss like this.
DaninVan is offline
post #6 of 122 (permalink) Old 06-25-2015, 07:15 PM
TwoSkies57's Avatar
Static discharge from a dust collection system has always seemed to me to be a bunch of hooey!!! I've never noticed enough static in my system to even consider it being a potential problem. That is not to say it wasn't there, I just never noticed it.................until!!!! Recently hooked up a Dewalt 735 planer. (an outstanding piece of equipment by the way). While running the first few board thru the new planer, I would reach around to grab the board as it exited the machine. I'm telling you what.. from 6"s away, there was enough static to make the hair on my arms stand on end!!! I will now incorporate some sort of grounding medium into my system.
Cricket and Roy Drake like this.
Skipper the Penguin
TwoSkies57 is offline
post #7 of 122 (permalink) Old 06-25-2015, 07:34 PM
tvman44's Avatar
First Name: Bob
My DC system is 4" PVC no grounding and I have never noticed any static problems. As for the DW735 you shouldn't be having a problem there if the electrical supply to the planer is properly grounded because that grounds the metal body of the planer. I recently got a DW735 and again not noticed any problems.
Cricket and Bort182 like this.
Papa Bob
Using a couple of old Craftsman routers & a Bosch 1617EVSPK & a Dewalt DWP611PK Routers in SW Louisiana.
tvman44 is offline
post #8 of 122 (permalink) Old 06-25-2015, 07:59 PM
Guys I've heard of grounding but never bothered . No incidents yet but I was using the hose to pick up dust off the floor and for the first time I noticed the hair standing up on my arm . Made me wonder
post #9 of 122 (permalink) Old 06-25-2015, 08:01 PM
I also question the idea of grounding the outside of a plastic pipe. The plastic piping systems I've seen advertised suggest running a wire down the inside and drilling a hole through near a connection so you can attach the inside to a bolt and another wire to the bolt on the outside. My preference was to use galvanized ducting instead. It's cheap and easier to ground. I still used the bolt idea but no wire needed on the inside. I also still used plastic ducting at the corners instead of galvanized bends. The plastic ones are much smoother. Use the aluminum foil duct tape at all joints and it works just as well.
Cricket likes this.
post #10 of 122 (permalink) Old 06-25-2015, 08:04 PM
Why take a chance? Very little effort and cost are required to avoid that potential problem. If static did cause a fire, the results would likely be catastrophic from your point of view.
JFPNCM, Stick486, Cricket and 2 others like this.
Index of Dust Collection Solutions and Comments allthunbs Shop Safety 28 03-14-2014 01:40 AM
Review - Rockler Dust Collection Separator (Small) Cochese Shop Safety 38 09-08-2012 09:22 PM
Oak Park Dust Collection kawisser Table-mounted Routing 3 08-18-2011 07:32 PM
Dust collection system for Router Table yhadar Lobby 2 12-31-2004 01:37 PM
You may not post new threads
