Your Favorite Jigs? - Router Forums
 58Likes
post #1 of 19 (permalink) Old 01-22-2016, 10:58 AM Thread Starter
Administrator
Router Forums's Avatar
Default Your Favorite Jigs?
Show me your favorite jig(s). Share pictures and comments about the shop built jig or jigs that help you the most.
Follow Router Forums on Facebook
www.facebook.com/RouterForums
Router Forums is offline
post #2 of 19 (permalink) Old 01-22-2016, 12:32 PM
CharleyL's Avatar
First Name: Charley
Default Favorite Jig - IBox
I like to make boxes, and my favorite jig for making them is my IBox jig.
It even made the corners of the box that I keep it in.
Edit,
Of course the forum decided to re-arrange the photos and it won't let me change the order of them or delete them.
Picture #2 and 6 are of the box for my IBox jig. Pictures #1, 3, and 7 are of my CRB-7 box, pictures #4 and 5 are of a box for a 9mm pistol.
All of the corners of these boxes were made using the IBox jig and a Freud SBOX8 blade on my Unisaw.
Charley
Central North Carolina
CharleyL is offline
post #3 of 19 (permalink) Old 01-22-2016, 01:00 PM
The one I use the most is my saw sled by quite a margin but my favorite is always the one I just finished building. It isn`t the jig that`s satisfying, it`s the problem solving that goes into it that is the satisfying part.
paduke, DaninVan, billyjim and 4 others like this.
post #4 of 19 (permalink) Old 01-22-2016, 01:14 PM
really haven't a favorite shop made...
Leigh jigs would rank at the top in commercially made...
neville9999 and Cricket like this.
post #5 of 19 (permalink) Old 01-22-2016, 05:37 PM
Honored Member
First Name: pat
Pictures 3, 4 & 5 = my favorite jig x far.
Can make a precise rectangle (or square) from scrap aluminum, wood, or plastic in just a couple of minutes. Up to ~12" x 24" x 1.5". Perfect for the jigs I make.
Collects its mess, instantly adjustable, the work never gets loose,
will cut to +/-.001", your hands are on the sleds away from the cutter, 4 locking swivel casters, carries its own vac.
last 1.0" of travel monitored x dial indicator, copy resolution =.001", what else is there?
Perfect for old people.
(No plans and not for sale.)
Quillman is offline
post #6 of 19 (permalink) Old 01-22-2016, 06:54 PM
favorite commercial jig, the one I use all the time is the Rockler Table Saw Sled. After I set it up, it delivers such precise cuts I can't believe how close they are. Table saw sleds are often shop made, but the ability to cut any angle (to the blade) up to 50 degrees delivers so much versatility that it has become my most used jig.
Among shop made jigs, I like my fairly new miter sled, (pix 1) set up to cut right on 45 degree angles for picture frames. I fussed like crazy while making it to make sure the angle was just right. Going to make one change. I made a sliding stop block that locks in place, but made it with a 45 degree angle (pix 2). Should have done a 90, square to the jig's fence. I will be changing that to get a more positive stop position. The 45 degree angle allows slop.
I recently made the small parts cutting jig (with the circular base, pix 3 below), which is close to being a work of art to me at least. I haven't had much chance to use it yet other than test cuts, but I know it will be very helpful in future as I do a few more fancy projects.
Name:	Miter Jig 01.jpg
Name:	miter jig02.jpg
Name:	mini trim japanese saw jig3.jpg
post #7 of 19 (permalink) Old 01-23-2016, 04:46 PM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Hi, Pat. Those are monster jigs!!!
My favorite one is the round tenon jig I made for Sabrina´s crib.
http://www.routerforums.com/general-...nd-tenons.html
Arcola60 likes this.
We, woodworkers are everywhere!!!
papasombre is offline
post #8 of 19 (permalink) Old 01-23-2016, 06:19 PM
First Name: Ellery
MilescraftStotsDovetail Template Master. I made it, with extra features. Sacrificial back plates, stops, toggle clamps, T-track,
And nice colors. It works great, for my needs. It can be used handheld or on the router table. Accurate and repeatable.
Name:	BUD - WIN_20140601_082604.JPG
Name:	BUD - WIN_20140601_082350.JPG
Name:	BUD - WIN_20140601_082349.JPG
Name:	BUD - WIN_20140601_082336.JPG
berry and timbertailor like this.
Arcola60 is offline
post #9 of 19 (permalink) Old 01-26-2016, 03:00 PM
First Name: Brad
This is the circle jig I made for my Festool OF1400 Plunge Router.
It holds itself up off the work surface, almost infinite adjustment with replaceable dual purpose track, and is easy to break down and stuff inside a systainer.
Just remember what my father always said, " Half the people in this world are below average!", and everything in life will make a hellova lot more sense.
timbertailor is offline
post #10 of 19 (permalink) Old 01-26-2016, 05:28 PM
that is well done...
KUDOS..
timbertailor likes this.
Oak Park spacer (box) jigs jw2170 Jigs and Fixtures 9 07-29-2013 09:08 PM
jigs from aluminum? meanbee Jigs and Fixtures 13 01-22-2013 06:31 AM
My Jigs and a template dan_house Jigs and Fixtures 11 06-03-2011 09:02 AM
What's your favorite jig(s) Jack Wilson Jigs and Fixtures 3 07-26-2010 09:41 PM
What do you finish your jigs with? istracpsboss Jigs and Fixtures 7 07-02-2010 02:56 PM
You may not post new threads
