Which Tools Would You Buy First? - Page 2 - Router Forums
 78Likes
post #11 of 63 (permalink) Old 04-19-2016, 08:03 PM
TWheels's Avatar
My first power tools were a power drill with drill bits, then a jig saw, then a power screw driver, then, after watching one episode of the Router Workshop, a 3 hp plunge router.
If I could turn back time and do it all over again, I would probably skip the jig saw and go straight to the router.
All that of course after years of hammer, saw, hand miter saw, screwdrivers, hex (Allen) wrenches, squares, sanding blocks, tape measure, level.
Although it would be far more efficient to hire @Stick486 to do it, both in terms of time and probably budget, the satisfaction of "I made that" is priceless!
I Want to Be the Person My Poodles Thought I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #12 of 63 (permalink) Old 04-19-2016, 08:04 PM
Seriously,give me a hammer, handsaw, square, tape measure, a wide3/4" chisel and a 1/4" chisel, a variable speed drill motor,set of drill bits to 1/4" and some wood bits, a screw driver bit, pry bar/nail puller,hand plane, a plumb bob, 2 'level and chalkline. and I will build you anything from a box to a house.
Herb Stoops is online now
post #13 of 63 (permalink) Old 04-19-2016, 08:04 PM
First Name: Earl
Starting fresh, knowing what i know now and how i work--and that a lot of tool repairs are not as complex as i still think...and assuming i've already got the sockets, screwdrivers, etc.
FIRST:
Starrett or B & S (even PEC) combination square (older is good) with 12", 18", 24" blades. (include protractor & center finder)
Dial indicator
Plastic drafting squares--a 45 and a 30-60
Straight edge--minimum 24", maybe 36"
Incra Guaranteed square (or similar)
Bit & Blade cleaner (i use Trend--but whatever the brand the key is to use it)
(I've learned the value of set-up, without it--everything else is harder. Without good set-up tools, any other tool has the potential to be a boat anchor)
NEXT:
8" Jointer--wish i'd never bought the 6", it makes it tougher to "justify" trading up to an 8"
Dewalt DW735 Planer+Byrd head--that was my 3rd planer, and the Byrd completes it. (someday, maybe a 15" to get me close faster, then i'll use the 735 to finish)
Dewalt Radial Arm Saw--i'm becoming a believer in my GWI. Can do probably 2/3 of my cutting, and they are so far out of favor a first-rate saw can be cheaper than bottom of the line portable table saw. (be sure to get "How to Master the Radial Arm Saw" by Wally Kunkel)
Bosch 1617 EVSPK (with Bosch edge guide & template kit) and 10 essential router bits--95% of my routing. Slot cutter with various sized bushings would take care of a lot of the rest.
EZ-One table, about 110" of track & 8" Makita circular saw--almost all of the rest of my cutting.
Saw blades--i've accumulated an assortment of Amana, Tenryu GM, Forrest, Freud Industrial, Infinity, Popular Tools (Carbide Processor's secret weapon), and i change them often so that i'm using blades made for the task. Not to be a snob, but the only combination blade i own has never been opened.
Good chisels, glass plates, and sandpaper--to fix my "learning opportunities"
Good cordless drill/driver kit--coupled with good bits.
Band saw--another "cry once" tool.
That's it for the "big tools". Probably could get by with no table saw. Look at the list above and it's a lot of money--but i'm living proof that one can spend more than that (maybe a good bit more) and not be there!!
earl
greenacres2 is offline
post #14 of 63 (permalink) Old 04-19-2016, 09:03 PM
Originally Posted by Ray Newman View Post
Dalboy said it all in a nutshell.
agreed...
post #15 of 63 (permalink) Old 04-19-2016, 09:06 PM
hand tools related to the task(s) at hand...
post #16 of 63 (permalink) Old 04-19-2016, 09:35 PM
If I have this right you want me to spend YOUR money on tool acquisitions and yur worried about ''THE BUDGET''...
good luck w/ that...
Ray Newman, DaninVan and HoweA like this.
post #17 of 63 (permalink) Old 04-19-2016, 10:11 PM
TWheels's Avatar
I was assuming you would use your own tools and bring your expertise.
TWheels is offline
post #18 of 63 (permalink) Old 04-19-2016, 10:33 PM
okay....
regular rates apply...
JFPNCM and vchiarelli like this.
post #19 of 63 (permalink) Old 04-19-2016, 11:39 PM
DonkeyHody's Avatar
First Name: Andy
If I'd known then what I know now . . .
I'd have bought or built a good workbench BEFORE I invested in stationary power tools like a table saw etc.
Ray Newman and Straightlines like this.
DonkeyHody is offline
post #20 of 63 (permalink) Old 04-20-2016, 02:32 AM
Like Derek and others have said, to what end and at what point in my life?
I bought stuff as I needed it...why would I change that if I were doing it over? Possibly different brands now, but no regrets over the previous.
Now if we're talking winning the lottery, BIG TIME, well that's a whole 'nother discussion. There'd be a planning session...I'm thinking 2 weeks in the Caribbean.
Oh wait; it's hot, Stick won't come! :0
JFPNCM, Nickp, Stick486 and 1 others like this.
DaninVan is online now
Edge Banding Router Bit Sets patlaw General Routing 15 02-02-2016 02:10 PM
Greetings! CharlesWebster New Member Introductions 19 11-30-2015 08:01 PM
Weekend Project patlaw Tools and Woodworking 18 08-08-2015 11:34 AM
New to the forum Zwervertje57 New Member Introductions 7 06-06-2015 12:10 PM
What tools to buy. mgmine Tools and Woodworking 15 04-03-2015 11:47 AM
You may not post new threads
