How Do You Stack Lumber? - Page 2 - Router Forums
 4Likes
post #11 of 16 (permalink) Old 05-11-2016, 02:12 PM
rrrun's Avatar
First Name: Henry
I fight the good fight of a small shop in my 2-car garage. The work area is about 16' x 18'; the lumber rack has 3 shelves that are 30" wide x about 2' high. It's 2x4 construction.
The lumber rack is a free-standing rack, 8' long. When I buy 10' boards, they stick out the front until they are processed. The top of the rack is 6' high, and it's covered with plywood to make a storage shelf.
6' & longer boards go into the rack. 5' & shorter are stored vertically until they are used ... and they are used first, to make room in the shop. Sheet stock is stored vertically while resting on its long edge, next to the rack.
2' & shorter boards are stored in various racks, cabinets & containers until I can use them to do what I do.
Router Forums likes this.
Henry
Santa Clarita, CA
www.MowryJournal.com
rrrun is offline
post #12 of 16 (permalink) Old 05-11-2016, 05:59 PM
I don't keep a lot of lumber around, but what I do have is laid horizontally in the shop on a wire shelf, or if long, it gets stored in the house on the floor or garage on the exposed rafters.
Baltic Birch ply gets stored vertically in the shop, but I clamp several sheets together in 5-6 places to avoid warping. Cheap ply and thin (backs) I buy as I need it. I can pre cut on my truck so I have smaller pieces to store.
Small offcuts get dropped into a bin.
post #13 of 16 (permalink) Old 05-16-2016, 08:49 AM
First Name: Barry
I have a small basement shop with poured concrete walls and plumbing taking up space on two of the walls. I wanted to use one wall for board storage but since the shop is below grade I really didn't want to put anchors into the walls and risk a leak. Instead, I attached 2 X 2's to the floor joists with a corner brace and an a couple of mending plates. Then attached a double track bracket to the 2 X 2's so the shelves could be adjusted for height. I laid either pine or poplar boards down first across the shelf brackets as a base then laid the various wood species on the shelves. This approach has worked out well.
As mentioned, I have a very small shop and most of my tools are on wheels. I used the same approach for sheet goods the largest pieces being 4 X 4. I found plans for a rolling sheet goods cart online and it holds all of my sheet goods and cut off.
Name:	Lumber Storage - basement wall rack.jpg
Name:	Lumber Storage - basement wall rack - hanger.jpg
Barry747 is offline
post #14 of 16 (permalink) Old 05-16-2016, 10:58 AM
I stack my boards flat in the rafters of my garage, they are supported by plywood underneath. When I reclaimed this redwood from a fence that was removed I ran it through my thickness planer to remove the coatings on both sides then stacked and stickered the boards to help them dry. This tool cart works great by the planer and for moving the boards to where I will store them.
Name:	Redwood clean up.jpg
post #15 of 16 (permalink) Old 05-17-2016, 04:08 AM
Honored Member
harrysin's Avatar
First Name: Harry
These are some of the places that I use for storage.
Cricket likes this.
Harry
harrysin is online now
post #16 of 16 (permalink) Old 06-01-2016, 12:06 PM
First Name: Darryl
I stack all my lumber horizontal with thin spacers placed at intervals along the length of each piece before another piece is placed on top. I alter the spacers from each other in the stacked lumber pile. The 1/8" spacers have been cut from scrap.This allows for air flow between each piece thus eliminating or at least minimizing warping and twist.
mcmahondl is offline
Router bits for Mortise and Tenon project? windhollowfarm Router Bits - Types and Usage 267 08-29-2018 12:19 PM
New to woodworking...where to buy lumber? embo5 Starting Off 14 11-18-2013 10:43 PM
Product Review - Oshlun 6" Dado Stack GulfcoastGuy Tool Reviews 18 11-14-2013 08:09 PM
Grading Of Hardwood Timber Gaia Wood Species 23 07-17-2013 04:12 PM
Using routers to plane/surface rough lumber sh2005 Jigs and Fixtures 18 01-28-2010 10:53 AM
You may not post new threads
