GIVEAWAY: SHARP 9,000 BTU Ductless Mini Split From ComfortUp - Page 2 - Router Forums
 36Likes
Closed Thread
post #11 of 215 (permalink) Old 06-09-2016, 04:49 PM
Fans for cooling and propane heaters in the winter months. I would install the heater in my shop.
Cricket likes this.
post #12 of 215 (permalink) Old 06-09-2016, 05:02 PM
Originally Posted by Oakwerks View Post
How do you keep your workshop area cool in the summer and warm in the winter?
In my well insulated stand-alone shop....
Radiant floor heat..
and it seldom gets much above 70° w/ really really low humidity..
berserk R levels of insulation..
Cricket likes this.
Stick486 is offline
post #13 of 215 (permalink) Old 06-09-2016, 06:17 PM
Semipro's Avatar
First Name: John_*
My shop is in the basement so I have it heat and air-conditioned.
If i was to get the SHARP 9000 I would install it in the garage because I have some larger equipment like panel saw and would like a larger CNC table
Cricket likes this.
Semipro is offline
post #14 of 215 (permalink) Old 06-09-2016, 07:36 PM
Jerry Spencer Mings's Avatar
First Name: Jerry
My workshop is so minuscule that in inclement weather, if a portable fan or space heater is insufficient, I must forgo the current project in favor of planing the next.
Cricket likes this.
Jerry Spencer Mings is offline
post #15 of 215 (permalink) Old 06-09-2016, 09:58 PM
difalkner's Avatar
First Name: David
Currently using a 12,000 BTU 22 SEER Gree mini-split for our attached and well insulated two-car garage in northwest Louisiana - hot, humid in the summer and colder than you would think in the winter.
Where will you use the Sharp Mini Split if you win?
I need a smaller shop out back for my guitar building and the Sharp mini-split would be perfect for that.
Cricket likes this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #16 of 215 (permalink) Old 06-09-2016, 10:07 PM
RainMan 2.0's Avatar
In the winter I take my iPad with me in the garage , then go to this site and let the sarcasm about my non insulated shop warm it up . Only helps a few degrees though lol
Ok ,I never insulate
RainMan 2.0 is online now
post #17 of 215 (permalink) Old 06-10-2016, 06:07 AM
JimofSC's Avatar
My shop in neither heated or cooled. I use window fans in the summer and a portable heater to preheat my shop in the winter.
I would use the Sharp Mini Split in my work shop to extend my "wookable day's".
JimofSC is offline
post #18 of 215 (permalink) Old 06-10-2016, 06:59 AM
First Name: Gary
Default A needed expansion
Since my shop is in my basement, it is conditioned by my home furnace/air. My shop is only 13'x19', and it would be nice to expand into my un-heated garage to gain shop space. I have not done so due to not being able to control the humidity to prevent rust. The heat pump sounds like a great solution for year around use and could be quite economical to run. I would use this in my garage.
gmercer_48083 is offline
post #19 of 215 (permalink) Old 06-10-2016, 07:05 AM
My shop/garage has no adequate climate control. It is heated in the summer and cooled in the winter largely by the local temperatures. Temperature extremes are moderated by a space heater in the winter and a south breeze in the summer. A mini split system would allow comfortable year around shop usage.
Tom
ThomL is offline
post #20 of 215 (permalink) Old 06-10-2016, 07:31 AM
Default This woulbe a good answer
I currently work in an uninsulated garage. It us unheated in winter and just have fans for summer.
This would do great with some insulation!:smile
westxjim is offline
Closed Thread
Win GREE Rio 9,000 BTU Ductless Mini Split Heat Pump Air Conditioner From ComfortUp Router Forums Featured Topics 319 06-16-2016 03:47 PM
You may not post new threads
