GIVEAWAY: SHARP 9,000 BTU Ductless Mini Split From ComfortUp - Page 3 - Router Forums
 36Likes
Closed Thread
post #21 of 215 (permalink) Old 06-10-2016, 08:33 AM
How do you keep your workshop area cool in the summer and warm in the winter?
rocket stove winter -- door and fan sumer
Where will you use the Sharp Mini Split if you win? in the shop (garage)
Cricket likes this.
chiefjd is offline
post #22 of 215 (permalink) Old 06-10-2016, 09:55 AM
First Name: Steve
Here in SW Georgia it gets extremely humid starting about mid May and stays that way until mid fall. During these times I generally do most of my woodworking with the doors open and a large noisy fan. I try to limit my time to early mornings and later evenings. This unit would be a great addition to my small shop where my grandchildren and I could work in a more comfortable environment.
kp91 likes this.
Knot2square is offline
post #23 of 215 (permalink) Old 06-10-2016, 09:55 AM
Wood Chip's Avatar
First Name: Gary
I've never had a workshop with heat, much less AC. But I've just moved into a home that has a dedicated workshop/office. I am right now investigating my options for heating and AC. A unit like this would be a wonderful solution.
Wood Chip is offline
post #24 of 215 (permalink) Old 06-10-2016, 10:04 AM
I work out of my basement shop in the Hudson Valley, NY. In the summer, it is usually pleasant enough temperature wise, but it is vey humid. In the winter, I have two of the oil filled radiators that struggle to keep the room bearable.
Thanks for having the contest.
Potowner1 is offline
post #25 of 215 (permalink) Old 06-10-2016, 10:07 AM
MEBCWD's Avatar
I would use it in the shop to heat and cool the shop when i was working on a project.
I would also setup a dedicated area that could be closed off with storage for wood, glues, stains, paints and finishes and let the unit keep the area at ideal temperatures for storage when I was out of the shop.
MEBCWD is offline
post #26 of 215 (permalink) Old 06-10-2016, 10:36 AM
First Name: Bob
In the summer, I open the garage doors and turn on a box fan. Doesn't really help with the humidity. However, I installed Attic Foil in the attic above the garage and this cuts down the heat. In the winter, I am at the mercy of the outdoor temp. I am considering insulating the garage doors. This is a 2 1/2 garage with approx 375 cu feet and the walls are insulated.
This is a no brainer for me. THE GARAGE.
Last edited by Web Shepherd; 06-10-2016 at 10:38 AM. Reason: spelling and new info
Web Shepherd is offline
post #27 of 215 (permalink) Old 06-10-2016, 11:55 AM
creative's Avatar
In peak heat (around 100F), I throw a few bags of ice on a clothes drying rack and set a 24in high speed shop fan behind it - like some kind of neanderthal!
When it's cold, I just put on some wooly mammoth skins. Or several layers of long sleeved shirts. Whichever is available.
Would use it to alleviate the scorch of one workshop, or the tundra of another, depending on the time of the year. Save me SHARP...
creative is offline
post #28 of 215 (permalink) Old 06-10-2016, 12:49 PM
richjh's Avatar
First Name: Rich
I work out of an insulated Colorado garage. I forego the shop during the coldest winter months, November thru February. In the summer, I open the side door and place a box fan to move air thru the shop area.
I would install it in my garage to allow for year round comfort.
Basically, a tool is an object that enables you take advantage of the laws of physics and mechanics in such a way that you can seriously injure yourself - Dave Barry
richjh is offline
post #29 of 215 (permalink) Old 06-10-2016, 01:01 PM
dachlion's Avatar
I'm using a floor fan for now in my basement workshop during the summer.
As for cold winter, I have a 65 000 btu wall heater and will warm up the workshop in a hurry.
This mini system would work great and be more comfortable for my workshop..
dachlion is offline
post #30 of 215 (permalink) Old 06-10-2016, 01:14 PM
gjackson52's Avatar
First Name: Gary
I have a natural gas heater in the garage for the cold MN winters, but summers are just a fan. So I would use the mini split to both heat and cool the garage, which is my shop.
Gary
gjackson52 is offline
Closed Thread
Win GREE Rio 9,000 BTU Ductless Mini Split Heat Pump Air Conditioner From ComfortUp Router Forums Featured Topics 319 06-16-2016 03:47 PM
You may not post new threads
