fixing magnets - Router Forums
 6Likes
post #1 of 22 (permalink) Old 11-24-2016, 09:21 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Default fixing magnets
I want to use some rare earth magnets on a trinket box lid to keep it closed.
How do you keep the magnets in place? i tried before but the lid magnet just kept pulling the lower one out of its socket.
sunnybob is offline
post #2 of 22 (permalink) Old 11-24-2016, 10:10 AM
kp91's Avatar
First Name: Doug
epoxy. CA glue works pretty well, but I've had it come loose.
rrrun likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 22 (permalink) Old 11-24-2016, 10:43 AM
What Doug said (epoxy). I've never had a failure with the epoxy method.
DaninVan is offline
post #4 of 22 (permalink) Old 11-24-2016, 11:07 AM
tighter socket and epoxy...
Herb Stoops likes this.
post #5 of 22 (permalink) Old 11-24-2016, 12:14 PM
I epoxied one to the side of my drill press to hold the chuck key but it did let go 15-20 years later. Then I realized that it will either stick to the DP or the chuck key so I didn't bother gluing it back on. These magnet cups that Lee Valley sells are supposed to hold the magnet in place. They are supposed to have a greater attraction that anything it comes into contact with. Maybe for insurance use the cup and some epoxy. Cups, Discs and Washers for Rare-Earth Magnets - Lee Valley Tools
post #6 of 22 (permalink) Old 11-24-2016, 01:07 PM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
This is a small box and I'm using 3mm wide magnets, so the cups wont go in. I've used superglue but with mixed effect.
I have a two part glue, I'll try that on a scrap piece.
sunnybob is offline
post #7 of 22 (permalink) Old 11-24-2016, 03:16 PM
First Name: Richard
My vote is epoxy. I've had some CA failures.
Shop guy is offline
post #8 of 22 (permalink) Old 11-24-2016, 03:58 PM
Knothead47's Avatar
Did a pet door project with a swiveling bar to keep the door from opening. Tight fit for the magnet and CA. That was three years ago and so far, so good.
John T.
Knothead47 is offline
post #9 of 22 (permalink) Old 11-24-2016, 04:59 PM
hawkeye10's Avatar
First Name: Don
One thing you could do is what ever you are using for the magnet to connect to make it very small. The smaller it is the less it will pull on the magnet when you open the box. The box being small it shouldn't take much to hold the lid shut.
paduke likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #10 of 22 (permalink) Old 11-24-2016, 05:54 PM
JOAT's Avatar
First Name: Theo
The ones I have all have a hole thru the center.
JOAT is online now
Repurpose magnets from a harddisk brille Show N' Tell 12 07-18-2016 03:55 PM
Fixing A Mistake Jerry Bowen Show N' Tell 20 04-26-2015 12:57 PM
Switchable Magnets Ben in Cypress Texas Jigs and Fixtures 21 10-27-2012 11:55 AM
HF Plate Magnets Zurt Table-mounted Routing 2 12-18-2010 08:01 PM
Fixing a knot Hamlin Tools and Woodworking 5 03-18-2010 01:19 AM
