How Many Use Airless for Finish - Router Forums
 5Likes
  • 2 Post By JOAT
  • 3 Post By JOAT
post #1 of 8 (permalink) Old 10-16-2017, 07:00 PM Thread Starter
First Name: lee
Default How Many Use Airless for Finish
I am trying to figure out if anybody really uses an airless sprayer for finishing their projects or kitchens?
I have an airless old Titan 440 e or XC can't tell, which I have used to paint a couple of houses, a garage and 2 roofs. It paints well but it takes like a quart to prime the unit and hose. Which seems fine if your going to spray 3 or 5 gallons. But if you are going to spray a few doors or a piece of furniture it seems like to much trouble to use an airless. Am I wrong in my thinking?
I have been using wipe on poly for some of my kitchen doors and I have been wondering if there is an easier way. Is there a setup for my airless which makes it easier to use for fine finish?
coxhaus is online now
post #2 of 8 (permalink) Old 10-16-2017, 08:41 PM
I've never thought of mine as a fine finish tool and it seems to use a lot of paint. Maybe I should try it sometime. For small projects like burl clocks I use a Binks air brush. It works really well and takes very little solvent to clean it. For projects a little larger I use a touch up gun. It was a cheap one but seems to work fairly well and has similar attributes to the airbrush. I also have a PC gun in full size that does a very good job for what I paid for but I rarely have projects large enough to use it on.
post #3 of 8 (permalink) Old 10-16-2017, 11:03 PM
JOAT's Avatar
First Name: Theo
Well, airless, and has always worked well for me, fine detail or not. Age old technology, and still works great.
Gaffboat and CharlesWebster like this.
JOAT is online now
post #4 of 8 (permalink) Old 10-16-2017, 11:04 PM
My experience with airless sprayers is that they take so much paint to prime, and then waste so much paint and solvent on cleanup that unless you are going to spray gallons of paint (I used one to paint the interior of my 20' X 30' shop in less than an hour) it's not worth the effort. BTW, it took most of 2 hours to clean up after spraying 6 gallons of paint on the walls and ceiling of my shop.
<Chas>
I'll burn that bridge when I come to it
CharlesWebster is offline
post #5 of 8 (permalink) Old 10-17-2017, 12:30 PM
JOAT's Avatar
First Name: Theo
I was going to go with a sprayer on the inside of my shop, but opted for paint roller instead.
And was very happy I did so. Cleanup: Paint pan - line with plastic, toss the plastic. Paint roller - toss the roller brush. Next step - put the lid on the paint can. Viola, cleanup completed.
JOAT is online now
post #6 of 8 (permalink) Old 10-17-2017, 05:48 PM Thread Starter
First Name: lee
What rig do you have and how do you use it? What finishes do you spray?
Do you start with a gallon of finish and just waste a quart? A quart is only maybe $7 so the cost is not that high. It takes me almost a gallon of paint thinner to clean my sprayer so add that in also. I think the total cost only comes to just under $20. I guess in the big picture that is not such a great cost. It is just hard for me to waste that much finish but maybe I need to rethink it.
post #7 of 8 (permalink) Old 10-17-2017, 06:28 PM
I pretty much stick to wipe on poly, mostly undiluted, but fresh. Knowing me, I'd put off cleaning up the gear and wind up having to replace nozzels every week or two. I use spray on lacquer occasionally, but from a can. The airbrush idea appeals to me, but the price is a little daunting compared to wipe on.
DesertRatTom is online now
post #8 of 8 (permalink) Old 10-17-2017, 11:48 PM
JOAT's Avatar
First Name: Theo
Can of paint, paint brush, then caveman style. Only spray bug repellent.
My only waste is what I drip on my pants and shoes. I use acrylic paint, so the thinner is water. I get it out of my tap, so doesn't cost much. My finish coating is Titebond II, low cost, thinner again water. As far as paint, latex is now as good, maybe better, than oil paint, and water cleanup. Yeah, might want to rethink it.
JOAT is online now
Recommend me an airless sprayer Router is still my name Tools and Woodworking 3 03-05-2007 02:53 PM
