Washer/Dryer Riser Finish - Page 2 - Router Forums
 9Likes
post #11 of 15 (permalink) Old 12-18-2017, 09:15 PM
I believe you are referring to MDO and not MDF and it's not the laminate that's the issue.. it's the core......
how many here have commercial outlets available to them...
post #12 of 15 (permalink) Old 12-19-2017, 02:13 AM
First Name: Wags or Tom
Yes the exterior version of MDF. Almost every large city has a commercial wholesaler. Or you can purchase through a local cabinet shop, have them order it for you when getting their order. I use to do that from time to time for customers. Opens you up to many more products available, and better quality. Most of the big box stores use import (think China) for their lumber products, not all but many.
wags is offline
post #13 of 15 (permalink) Old 12-19-2017, 04:57 AM
we can throw HDO and MFC into the mix too....
why bother...
solid core laminate some plywood and be done w/ it...
post #14 of 15 (permalink) Old 12-19-2017, 11:13 PM
why bother...
I'm not speaking about MDO (medium density overlay over plywood) Look up Medex, it's the largest supplier of exterior MDF. It is 100% MDF used in outdoor signage nation (possibly world) wide.
wags is offline
post #15 of 15 (permalink) Old 12-21-2017, 09:07 AM
Pots43's Avatar
I know this is late. I did this 11 years ago and it is holding up well. I used ceramic tile, which a lip.
Pots43 is offline
Finish for Grandson's Toy Box chuckgray The Finishing Touch 26 11-05-2015 09:29 AM
Unidentified cutting board finish Barry747 The Finishing Touch 15 10-06-2015 11:51 AM
Finishing the way I see it! by Derek Willis. derek willis Woodworking Articles 0 02-28-2011 09:44 AM
Water based finish over oil based finish? ffjdh The Finishing Touch 10 05-18-2010 06:54 AM
