Washer/Dryer Riser Finish - Router Forums
 9Likes
post #1 of 15 (permalink) Old 12-12-2017, 02:46 PM Thread Starter
Default Washer/Dryer Riser Finish
Not "fine woodworking" by any means but am making a riser for a washer/dryer combo and question the finish to use. The riser is 3/4" plywood atop dimension lumber sides. The washer weights over 200# empty and sits on two fixed steel feet and two adjustable nylon feet. Very high pressure for a small area. The dryer sits on rubber feet and weighs mush less.
I want to finish it in white if possible. Am afraid of latex as the rubber feet will surely stick and lift it and the washer may become permanently attached. Thinking of white shellac with a poly varnish over the top. If I would do this should I use oil based or water based poly? Is this even a good idea?
Suggestions appreciated, trying to get this done by Christmas and running out of time (so what's new there?).
senebraskaee is offline
post #2 of 15 (permalink) Old 12-12-2017, 03:03 PM
go w/ high pressure laminate.. (Formica)...
looks good and easier to maintain..
Danman1957 likes this.
post #3 of 15 (permalink) Old 12-12-2017, 04:46 PM
I would tend to agree if you want maintenance free. Only issue is that it's slick and washers tend to vibrate so I would put a rim around the edge to make sure the washer stays on it.
Along the same lines, I've decided never to make another cupboard that will have a sink in it without laying laminate on the bottom in that section and caulking around the edges. There is always a leak of something eventually and that winds up destroying the bottom in that section.
post #4 of 15 (permalink) Old 12-12-2017, 05:14 PM
Amen to that, Charles!
I don't know that I've ever seen a sink cabinet that didn't have at least little bit of water staining on the floor of it.
Like a boat that's never had water in the bilges.
DaninVan is offline
post #5 of 15 (permalink) Old 12-17-2017, 02:16 AM
First Name: Wags or Tom
Use a TFM panel (thermally fused melamine) same as laminate and no glue line to fail. Also less expensive and comes in many colors.
wags is offline
post #6 of 15 (permalink) Old 12-17-2017, 02:23 AM
Hi Wags and welcome. I haven't seen it for sale anywhere here.
post #7 of 15 (permalink) Old 12-17-2017, 04:13 AM
we do know that as Melamine...
if it's MDF or fiber/particle/wafer board core it won't take much abuse or withstand the vibration/resonation of the washer/dryer as in the fasteners won't hold and it will self destruct......
all bets are off if it gets wet...
there is a soft wood veneer core version (best and only real choice) but it's not readily available as in, in stock, around here... gotta be ordered...
post #8 of 15 (permalink) Old 12-17-2017, 04:14 AM
https://www.interiorsandsources.com/...-and-interiors
post #9 of 15 (permalink) Old 12-17-2017, 11:23 AM
I've never seen it at Windsor Plywood, Home Depot, or Home Hardware here which are my 3 sources. Is it waterproof like HPL? The regular melamine isn't. Water, orange cleaner, and even dish soap sitting on it for any length of time eats through the regular melamine.
post #10 of 15 (permalink) Old 12-18-2017, 03:21 PM
That use to be true but today they make Exterior MDF which is used in outdoor sign making extensively. If you use a good quality MDF or even Particle board (not Box Store junk) and use biscuits or splines it will be as strong as any product. TFM has the same exact wear qualities as standard laminate, just not the impact resistance. TFM panels are water resistant as standard laminate, it's why you see only two sided board, so it's balanced. It is use in commercial applications world wide. The only difference is laminate has additional layers of resin impregnated paper sheets behind the decorative sheet.
It is available most places but you need to go through a good lumber wholesaler, the guys that sell to Millhouses. If you look at Roseburg or Panalam, two of the larger suppliers of TFM you can see who wholesales it in your area. Here in Phoenix, Spellman Hardwood stocks over 50 colors of TFM.
You may be mistaking a vinyl overlay available at some big box with TFM. Vinyl can be one sided and it is not water resistant. If you see any board which is finished only one side you can assume, rightfully so, that is it not water resistant. All board needs to be balanced to prevent warping, if you finish one side moisture will get in through the unfinished back..
Send some pics of your finished product...im getting old and thinking of raising the dryer up, since it's getting harder and harder to stoop over and reach into the back of the dryer.
wags is offline
Finish for Grandson's Toy Box chuckgray The Finishing Touch 26 11-05-2015 08:29 AM
Unidentified cutting board finish Barry747 The Finishing Touch 15 10-06-2015 10:51 AM
Finishing the way I see it! by Derek Willis. derek willis Woodworking Articles 0 02-28-2011 08:44 AM
Water based finish over oil based finish? ffjdh The Finishing Touch 10 05-18-2010 05:54 AM
