Bubinga Finish Help - Router Forums
 4Likes
  • 2 Post By sunnybob
  • 2 Post By kywoodchopper
post #1 of 8 (permalink) Old 12-25-2017, 08:28 PM Thread Starter
KhalTom's Avatar
Default Bubinga Finish Help
I made a cabinet out of Bubinga. It's fairly decent siE 36" x 34" . It's a wall cabinet to hold a bunch of glasses. Their is absolutely no chance if water or liquids, more of a display type deal.
Now im getting ready to finish it and I'd like to make it look really nice. Ive had a lot of luck with Formbys Tung Varnish. I was thinking i could just out a few coats of this on ...
Im looking for any ideas. Anyone have experience finishing bubinga?
Sent from my SM-N950U using Tapatalk
KhalTom is offline
post #2 of 8 (permalink) Old 12-26-2017, 02:13 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I've used a lot of bubinga in my boxes, I like wipe on poly as a shiny finish, looks amazing on side grain as you can see on this butterfly box made of walnut and bubings layers.
Not so keen on oil finishes as the wood doesn't show off its true colour so well, but that's personal preference.
http://www.routerforums.com/show-n-t...erfly-box.html
Danman1957 and hawkeye10 like this.
sunnybob is offline
post #3 of 8 (permalink) Old 12-26-2017, 08:10 AM
hawkeye10's Avatar
First Name: Don
Tom you might try shellac. You could wipe it on with a soft cotton cloth. Always do a test first no matter what you use as a top coat.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #4 of 8 (permalink) Old 12-26-2017, 08:13 AM
kywoodchopper's Avatar
First Name: malcolm
I have made boxes including funeral urns out of bubinga. The finish that I used was 3-coats of wax-free shellac diluted 50/50 with denatured alcohol. I wait 8-hours between coats to let them cure. I do not sand between coats. I then apply Zar polyurethane diluted 50/50 with mineral spirits. I generally apply 5 or 6 coats waiting 8-hours between coats. I apply this with the blue paper shop towels that I have cut into 1/4's then folded until it is about 2" square. Hope this helps. Malcolm / Kentucky USA
whimsofchaz and hawkeye10 like this.
kywoodchopper is offline
post #5 of 8 (permalink) Old 12-26-2017, 11:17 PM Thread Starter
KhalTom's Avatar
I have several small diver like hikes that i believe were put in by planing. Very deep. How can o fill them? Should sanding sealernfill them?
KhalTom is offline
post #6 of 8 (permalink) Old 12-27-2017, 01:04 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I would sand the whole panel smooth. fillers almost always show up under the finished coat
sunnybob is offline
post #7 of 8 (permalink) Old 12-30-2017, 10:31 AM
hawkeye10's Avatar
First Name: Don
Malcolm why do you wait 8 hours for shellac to cure? I thought shellac would bond to itself therefore you may not have to wait 8 hours. I know you have a good reason I would just understand the reason.
Just trying to learn something. Thanks
post #8 of 8 (permalink) Old 01-01-2018, 07:47 AM
First Name: malcolm
I apply shellac the same way I do with all finishes using the blue paper shop towels. If I don't wait several hours between coats of shellac to cure the first coat becomes gummy when applying the next coat. On oily woods I have found that if I wait several hours I don't have that problem. On all other woods (cherry, walnut, maple) I generally wait an hour or so between coats.
Finish for Grandson's Toy Box chuckgray The Finishing Touch 26 11-05-2015 09:29 AM
Unidentified cutting board finish Barry747 The Finishing Touch 15 10-06-2015 11:51 AM
Finishing the way I see it! by Derek Willis. derek willis Woodworking Articles 0 02-28-2011 09:44 AM
Water based finish over oil based finish? ffjdh The Finishing Touch 10 05-18-2010 06:54 AM
