Realistic Copper Plating Using Home Made Paint - Page 2 - Router Forums
 28Likes
post #11 of 18 (permalink) Old 01-25-2018, 08:28 PM Thread Starter
Dejure's Avatar
First Name: Kelly
Here is one I tried today using just the copper powder and ModPodge.
The reason I have what you want is, I never lent it out before.
Scraps are a myth.
Dejure is offline
post #12 of 18 (permalink) Old 01-27-2018, 12:50 PM
CharleyL's Avatar
First Name: Charley
The copper paint used to prevent algae and barnacle growth on boats might work well for this and be easier to buy rather than make. Just a suggestion.
Charley
Central North Carolina
CharleyL is offline
post #13 of 18 (permalink) Old 01-27-2018, 02:02 PM
Charley, those Marine paints have Copper compounds in them; they don't really look very Copper like...too many other ingredients. The standout might be 'CopperCoat' which does look like Copper.
Those anti-fouling paints are reaaaallly expensive. The Copper content has been greatly reduced due to environmental issues.
Coppercoat: A Worthy Alternative to Bottom Paint - boats.com
DaninVan is offline
post #14 of 18 (permalink) Old 01-27-2018, 02:07 PM
One of the reasons that it's more difficult to find the fine ground metals (at retail) is that they're ideal for making Thermite. Don't ask me how I know this...
Thermite: 4 Steps
DaninVan is offline
post #15 of 18 (permalink) Old 01-27-2018, 09:35 PM
Gaffboat's Avatar
First Name: Oliver
Thermite: 4 Steps
Ah, thermite. Amazing stuff. We always had a thermite grenade next to our howitzers in case we got overrun and had to abandon our guns. Pull the pin, drop one down the barrel and no one was ever going to use that gun again. I'm happy to say we never needed one. There was also a big flat thermite device that sat on top of our crypto file cabinets. One pull of the pin and the entire cabinet would be melted ash in a matter of seconds.
DaninVan likes this.
Gaffboat is offline
post #16 of 18 (permalink) Old 02-02-2018, 12:03 AM Thread Starter
Dejure's Avatar
First Name: Kelly
And thermite is the reason you don't sand and grind a lot of aluminum and metal on the same belt.
Scraps are a myth.
Dejure is offline
post #17 of 18 (permalink) Old 02-02-2018, 12:11 AM Thread Starter
Dejure's Avatar
First Name: Kelly
As to copper paints, as mentioned, they run into the area of $150.00 a gallon and the price per ounce goes way up as your containers get smaller. Pretty expensive experiments. Copper powder isn't horribly expensive. I bought a pound for about $16.45 and a large bottle of ModPodge was about seven. That makes a LOT of product.
DaninVan and ggom like this.
Scraps are a myth.
Dejure is offline
post #18 of 18 (permalink) Old 02-02-2018, 11:33 AM
Default Cutting Edge
I've mentioned this before; if you're using your angle grinder with cutting discs for cutting Aluminum, get the ones that are specifically for Aluminum!
If you can't find them on the rack, and the clerk thinks you're nutz, educate him/her!
https://www.walter.com/en_US/product...utting/zip-alu
ggom likes this.
DaninVan is offline
Home made loose tenon machine Skootapaul New Member Introductions 7 09-14-2014 11:20 PM
overcomming home made router table snags matey Table-mounted Routing 5 01-27-2011 08:36 PM
Which base do I use on my home made table? popeyebedford Table-mounted Routing 1 07-08-2007 02:56 PM
Home Made Cam Clamps... Joe Lyddon Tools and Woodworking 2 11-28-2006 11:07 PM
Home made mitre fence? normcatalunya Jigs and Fixtures 9 11-01-2005 03:51 AM
