Northern White Cedar - Router Forums
 7Likes
post #1 of 11 (permalink) Old 02-12-2018, 07:01 PM Thread Starter
TwoSkies57's Avatar
Default Northern White Cedar
I"m lookin for a little feedback on northern white cedar. Particularly successful finish schedules for exterior use...
I"d be interested in any experience, good or bad..
thanks
bill
Skipper the Penguin
TwoSkies57 is offline
post #2 of 11 (permalink) Old 02-12-2018, 07:09 PM
wi8ll this help???
http://cedarfurnitureoutlet.biz/finish_options.htm
post #3 of 11 (permalink) Old 02-12-2018, 08:20 PM Thread Starter
TwoSkies57's Avatar
Thanks Stick...
I ran across that last night and read up............leaning towards just leaving it alone......
Skipper the Penguin
post #4 of 11 (permalink) Old 02-12-2018, 10:35 PM
I've tried varathane and as Stick's article suggests it didn't hold up that well (on red cedar that is). I've had the best luck with opaque oil stains. The red cedar turns gray in sunlight. There have been and may still be a few split cedar shake roofs in the area that were 100 years old and still not leaking. Cedars that were killed in forest fires and then split last the longest of all. Same goes for fence posts made out of those trees. Farmers would split them 8 feet long and after 25 to 30 years drive them in another 12-18" and they would go for a total of 50 years or more. The fires case hardened them a bit and made them more weather resistant for some reason.
post #5 of 11 (permalink) Old 02-13-2018, 10:22 AM
Danman1957's Avatar
The local lumber yard advised me not to use Cedar for any furniture with glued joinery. They said screws do ok, but cedar is not very good for furniture. I am planning on making a patio set and was hoping to use Cedar, but was told to use White Oak instead and the higher cost would be offset by the longer life of the much more expensive wood. Does anyone know if Walnut does well as outdoor furniture ???
On Cedar fences and decks I have used Cedar stain or just wood sealer and love the look. The sealer however must be re-applied regularly depending on your climate.
Don't fear your tools, pay attention and respect the tools and avoid injury.
Danman1957 is offline
post #6 of 11 (permalink) Old 02-13-2018, 10:37 AM
yes on the Walnt... (black)...
File Type: pdf woods suitable for outdoor projects chart.pdf (2.44 MB, 33 views)
Danman1957 and DesertRatTom like this.
post #7 of 11 (permalink) Old 03-09-2018, 11:16 AM
hawkeye10's Avatar
First Name: Don
Cypress may be a good wood. If you get walnut that hasn't been steamed it cost a lot to. I have been paying $5.25 a board foot for steamed walnut but not anymore. I don't like it.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #8 of 11 (permalink) Old 03-09-2018, 05:36 PM
Semipro's Avatar
First Name: John_*
Bill
Found this article might help,
http://www.cedarfurnitureoutlet.biz/finish_options.htm
Semipro is offline
post #9 of 11 (permalink) Old 03-09-2018, 09:10 PM
hawkeye10's Avatar
First Name: Don
Have you ever seen a farm fence with cedar post? After a few years, the heartwood will be standing, but the white wood will be rotted away and the post will be loose in the ground. In another few years, the fence will be holding the post up.
post #10 of 11 (permalink) Old 03-09-2018, 10:01 PM
Second growth red cedar (young trees) last from 6-8 years as fence posts. If you cook/heavily scorch them in a fire 8 years, maybe a little longer. Old growth red cedar (200-300 years plus) last much longer. If those same 200-300 year old trees were killed in a fire first then double as long. Why that is I don’t know but there is an an abundance of local experience to back that up.
Cedar Chests Tonto1 Tools and Woodworking 8 09-14-2017 12:51 PM
Laminating Cedar Fence Pickets Frankj3 Sign Making 28 04-11-2016 11:09 AM
How do i line a cedar chest? Jerry Bowen Tools and Woodworking 10 10-22-2012 05:54 PM
Finishing white cedar bobbotron The Finishing Touch 3 12-11-2010 10:43 PM
Cedar Pergola TRN_Diesel DIY and Renovation 11 06-11-2010 08:49 AM
