Sanding after final coat of Poly? - Page 3 - Router Forums
 22Likes
post #21 of 23 (permalink) Old 03-19-2018, 10:25 AM
Honored Member
harrysin's Avatar
First Name: Harry
I never use water based finishes. Most often I use rattle can high gloss lacquer and rub down between coats with 0000 wire wool, after which I thoroughly clean with a tack rag before spraying the final coat.
Now, with Danish oil I apply usually five coats, no rubbing down in between coats and
then apply the sixth coat and leave it to fully harden over a few days. Then, using 0000 wire wool lubricated with wax polish, preferably Johnsons, which is no longer available in Australia, I give a good rub down, the more it's rubbed the higher the gloss.
As a matter of interest, Johnsons polish is now only available in America and the cost of freight is FAR more than the cost of the polish.
Harry
harrysin is online now
post #22 of 23 (permalink) Old 03-19-2018, 10:57 AM
Garyk's Avatar
First Name: Gary
[QUOTE=Cherryville Chuck;1863546]I've read articles by some of the contributors of fine Woodworking saying that on a high dollar commission that they will often send the item out to a pro to be finished. It is that complex a task and the results from having it done right can be as important, or more important, than doing a stellar job of the build.
Google "French Polish" technique. Watched it done one time and it is what is used to get the deep mirror finish on $$$$ pianos. Been a long time so I don't remember the details other than he kept using steel wool between coats. I'm sure he used some kind of compounding agent.
Garyk is offline
post #23 of 23 (permalink) Old 03-19-2018, 06:09 PM
First Name: Al
With poly it depends on the finish you are looking for. If you are looking for stain (mat) finish stop at 1200 grit wet & dry. Work you way all the way up to the final finish. If you want a high gloss then work your way up to 3000 grit wet & dry. Watch the edges as you can burn through real easy.
HD74_al is offline
Finishing kywoodchopper General Routing 13 01-15-2018 02:05 PM
Final coat over min wax wood finish RetiredJake The Finishing Touch 4 07-30-2013 10:25 AM
Finishing the way I see it! by Derek Willis. derek willis Woodworking Articles 0 02-28-2011 09:44 AM
wipe on stain clear coat more stain (layers) tiggol The Finishing Touch 6 03-22-2010 11:35 AM
