Sanding grooved wall paneling? - Page 2 - Router Forums
 8Likes
post #11 of 11 (permalink) Old 10-29-2018, 04:05 PM
Staining lighter is in theory at least, almost impossible. The ambient light goes through the coatings and is reflected back again through those same coatings. The amount of light you see, and it's apparent colour, has been reduced (dramatically!) from what went in.
The "lighter" colour will only be what's reflected back from the particles on the way in. You can't really stop the darker tones from reflecting back as well, hence what Stick said about bleaching the wood first!
If you have a MOHAWK FINISHES outlet close to you, i'd suggest you go and have a chat with them. They have a solution for just about any situation. Take a sample or a picture of the existing with you!
A lot of their products need to be sprayed, not brushed...
https://woodrepairproducts.com/wp-co.../PFS_Guide.pdf
https://www.mohawk-finishing.com/res...sk-the-expert/
https://www.mohawk-finishing.com/whe...a-distributor/
DaninVan is online now
High gloss sanding tip difalkner The Finishing Touch 33 06-18-2018 09:02 PM
Sanding Station? rrrun Tools and Woodworking 8 06-23-2017 02:11 PM
The Basic Wall Cabinet MT Stringer Project Plans and How To 15 04-05-2015 05:57 PM
Alcove Entertainment wall desk & cabinets gwizz Show N' Tell 30 05-21-2013 06:16 AM
Sanding BernieW Woodturning and Lathes 9 12-29-2011 08:01 PM
