Sanding grooved wall paneling? - Router Forums
 8Likes
post #1 of 11 (permalink) Old 10-28-2018, 03:16 PM Thread Starter
Question Sanding grooved wall paneling?
Is there such a thing as a sanding block that can sand into grooves in wall paneling? Thanks!
Peachy is offline
post #2 of 11 (permalink) Old 10-28-2018, 04:36 PM
Peachy the easiest way would be to take a strip of wood that just fits the groove and glue some sandpaper to the end. Welcome to the forum by the way. Trying to get into the lips on either side is a lot trickier. Do you need to do that too?
Peachy likes this.
post #3 of 11 (permalink) Old 10-28-2018, 04:53 PM
called a profile sander...
multimaster is the top dog..
Bosch is next...
HF, PC, Rockwell and Ryobie are junk...
Danman1957 and Peachy like this.
post #4 of 11 (permalink) Old 10-28-2018, 06:00 PM
Peachy; welcome!
Man, your question brought back old memories, and I don't mean good ones...
Back in the '50s there was a paneling product, basically hardboard, with triple grooves every foot or so (if I remember correctly).
Thee front face of the board was burnished to a hard smooth surface which didn't like paint
Trying to paint the grooves without leaving globs was a R.P.I.T.A !!!
Peachy likes this.
DaninVan is offline
post #5 of 11 (permalink) Old 10-28-2018, 09:10 PM Thread Starter
Thanks! This paneling has several grooves, so I might not be able to do what I need to do. It has been stained, and I want to stain it a lighter color.
Peachy is offline
post #6 of 11 (permalink) Old 10-28-2018, 09:11 PM Thread Starter
Thanks, Stick486! I'll check into this! There are several grooves in the paneling about every 5-6".
Peachy is offline
post #7 of 11 (permalink) Old 10-28-2018, 11:20 PM
bleach it... but experiment...
Chlorine bleach, full strength, easily removes most dye-based stain but will not bleach raw wood white, nor will it remove pigment-based stain.
Two-part wood bleach takes the color out of most dark woods and blends maple heartwood color with its sapwood.
Apply A/B bleach safely. Wear long neoprene gloves, with ends cuffed to catch drips, a waterproof apron, and goggles. Brush carefully. A/B bleach is extremely caustic and will quickly burn your skin and eyes.
Oxalic acid dissolved in water removes black iron stains like magic from tannin-rich wood like oak.
30%+ peroxide is a good one to try also...
for control use a grout sealer applicator...
post #8 of 11 (permalink) Old 10-29-2018, 11:52 AM
Garyk's Avatar
First Name: Gary
HEY STICK, I have a Dremel (piece of junk) that I bought in the 90's that still works. It has various rubber profiles that the sanding loop goes around and sands in odd places. Full disclosure: it has not been used in a commercial setting and probably would not hold up to daily use but it's reasonably inexpensive and for one off use it would work fine. Most of the time I follow Chucks method and just shape a wood block as needed and use adhesive backed sandpaper. That works best for us penny pinchers.
Never tried to stain the stuff but have filled the grooves and painted it.
Cherryville Chuck and Peachy like this.
Garyk is offline
post #9 of 11 (permalink) Old 10-29-2018, 12:38 PM Thread Starter
I've attached a picture of the room I want to redo. The paneling is stained with a green pickling look. I want to lighten the stain. Thanks!
Peachy is offline
post #10 of 11 (permalink) Old 10-29-2018, 01:03 PM
I originally was thinking you meant T slots so disregard the part about lips in my original post. The part about just gluing sandpaper on a strip of wood still applies. I have a set of different sized dowels with 80 and 120 grits glued to them for rounded grooves, ogees, etc. Works well and costs virtually nothing.
High gloss sanding tip difalkner The Finishing Touch 33 06-18-2018 08:02 PM
Sanding Station? rrrun Tools and Woodworking 8 06-23-2017 01:11 PM
The Basic Wall Cabinet MT Stringer Project Plans and How To 15 04-05-2015 04:57 PM
Alcove Entertainment wall desk & cabinets gwizz Show N' Tell 30 05-21-2013 05:16 AM
Sanding BernieW Woodturning and Lathes 9 12-29-2011 07:01 PM
