Need ideas to finish an inlay - Page 3 - Router Forums
 43Likes
post #21 of 26 (permalink) Old 04-07-2019, 07:49 PM Thread Starter
First Name: Mickey
Originally Posted by MEBCWD View Post
Looks good Mickey. Good choice of woods.
They do look good together (the woods). However, that cedar board wasnít fully flat and i donít have a planer. The whole project was just practice anyway so i went with what i had. I wanted to prove that my stencils workedand weíre lined up properly. Iím pleased with that aspect. However, due to the cedar not being flat, the inlays required lots of sanding in some spots. This is very noticeable when the light hits the piece just right. You can clearly see where the cedar was eaten up by the sandpaper. There are very shallow ďbowlsĒ around each letter. Maybe a card scraper will be included in my next order of supplies, unless yíall would recommend a small handheld planer for making the inlays flush and smooth.
Overall Iím still pleased and will likely use two hardwoods next time.
Sent from my iPhone using Tapatalk
Mickeyfolse is offline
post #22 of 26 (permalink) Old 04-07-2019, 07:55 PM Thread Starter
First Name: Mickey
Hereís another one recently finished. Itís 2Ē thick cedar glue up, with walnut inlay. About 24Ē tall by 17Ē wide.
I do not think Iíll be using cedar much for backboards anymore. This is the first glue up Iíve ever done and had to use my router table with an offset outfeed fence. Iím mostly pleased with how it came out.
The thing that bothers me about this piece is that when i clamped down the bottom right piece of the B, i didnít realized i turned the piece of walnut before i cut it out and the wood grain direction is way off. But the inlay itself came out pretty good.
marecat3, TenGees and Herb Stoops like this.
post #23 of 26 (permalink) Old 04-08-2019, 04:26 PM
Mickey; is there a cabinet or millwork shop near you, with a stroke sander? Perhaps for a bit of cash they'd let you sand your panels? Or just use a belt sander...you need a larger footprint on the sanding area than a ROS will provide.
$1,000 would buy you a new open arm drum sander if you don't already have one.
Mickeyfolse likes this.
DaninVan is offline
post #24 of 26 (permalink) Old 04-09-2019, 08:23 PM Thread Starter
First Name: Mickey
I don't have a drum sander but i do have a pretty decent belt sander. It's how i flattened (mostly, lol) the glue up for the big letter B. That one wasn't much trouble as it was flat enough. Not perfect, but plenty flat enough.
Sent from my iPad using Tapatalk
DaninVan likes this.
post #25 of 26 (permalink) Old 04-09-2019, 09:23 PM
Perfect is overrated...
DaninVan is offline
post #26 of 26 (permalink) Old 04-10-2019, 11:34 AM
First Name: mary
Both look wonderful
marecat3 is offline
Outdoor finish in Florida Barry747 The Finishing Touch 27 06-06-2018 07:37 PM
Wood Inlay Templates-More Possibilities w/ More Layers TarterWoodworking Jigs and Fixtures 10 06-08-2015 07:55 AM
Is this finish good for the toys I'm making? Gweedz The Finishing Touch 8 02-11-2011 02:25 PM
Water based finish over oil based finish? ffjdh The Finishing Touch 10 05-18-2010 06:54 AM
Inlay Guide Bushing and base plate Doyle Portable Routing 3 06-07-2007 10:25 PM
