Need ideas to finish an inlay - Router Forums
 43Likes
post #1 of 26 (permalink) Old 03-25-2019, 12:52 PM Thread Starter
First Name: Mickey
Default Need ideas to finish an inlay
So Iím almost done with this project. I didnít have a piece wide enough to finish the S but it should be in the mail today.
The inlay is Purpleheart on a cedar background.
I like using tung oil but Iíve read in a few places to not use oil on Purpleheart. As it stands some of that Purpleheart had to be put in the oven to restore the purple color.
So i am asking for suggestions on how to finish this piece. I donít need a super high gloss, but a little shine would be ok.
Iím also open to suggestions for finishing the edges, routing a border groove, etc.
Sent from my iPhone using Tapatalk
Mickeyfolse is offline
post #2 of 26 (permalink) Old 03-25-2019, 02:05 PM
Gene Howe's Avatar
First Name: Gene
Thats going to be a gorgeous sign. I've never used purple heart. I've heard it may bleed so, I'd use a water based spray finish. Water based dries pretty fast. Spraying would eliminate any transfer of the color you might get from a wipe on or brush application.
I wouldn't add a border. And, any routered profile would be as to your tastes.
DaninVan likes this.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 26 (permalink) Old 03-25-2019, 04:09 PM
NO,NO,NO,NO,NO....... No water base directly on Purple Heart. I just got through resanding off the water base Poly and putting on shellac. Maybe water base over the sealed purple heart might work, but not directly on it. It will be beautiful with the shellac, I use spraycan shellac Zinnser,and give it at least 4 coats lightly hand sanding in between with 400g.
Purple heart will turn a very dark almost black purple over time. Sunlight will also bring out the purple when it is newly finished.
Herb Stoops is online now
post #4 of 26 (permalink) Old 03-25-2019, 04:10 PM
Is it going outdoors, Mickey? I may be mistaken but I was under the impression that Purple Heart doesn't like UV.
If it is going outside then you may need to include UV filtering in the finish(?). I hope I'm mistaken 'cause that's too pretty a sign to be ruined by sunlight.
jj777746 likes this.
DaninVan is offline
post #5 of 26 (permalink) Old 03-25-2019, 04:15 PM
Gene the Problem I had with water based MinWax Acrylic was it turned the purple heart the most awful greenish black, like swamp mud color right away. I have not had any experience with bleeding into adjacent colors, Paduk is the one that really bled for me.
post #6 of 26 (permalink) Old 03-25-2019, 04:50 PM Thread Starter
First Name: Mickey
I will be using UV blocking in whatever i use.
post #7 of 26 (permalink) Old 03-25-2019, 04:51 PM Thread Starter
First Name: Mickey
Interesting, Herb. From my reading, it seems that most people recommend waterbased finishes, with UV inhibit.
post #8 of 26 (permalink) Old 03-25-2019, 04:55 PM Thread Starter
First Name: Mickey
Also, i appreciate the compliments. I am very new to doing inlays. This in the fourth attempt Iíve made at doing an inlay. Pics of the first three are in the Guide Bushing and Template forum.... as making the template, or stencil, is the real art to doing this. Thatís what takes the most time and has no room for error. Each letter took two to three hours just to make the stencil. But i now have it and itís reusable! Hopefully Iíll eventually have the whole alphabet and will offer them as printouts to you guys. Just gotta be sure it prints correctly. Ive learned a lot from you all.
post #9 of 26 (permalink) Old 03-25-2019, 05:59 PM
Gene Howe's Avatar
First Name: Gene
Thanks for the correction of my suggestion, Herb. It was a guess on my part. Glad you chimed in before disaster struck. I'd really hate to be the reason for screwing up all that work on such a beautiful project.
Herb Stoops likes this.
Gene Howe
Snowflake, AZ
post #10 of 26 (permalink) Old 03-25-2019, 06:06 PM
we can blame you anyways....
Outdoor finish in Florida Barry747 The Finishing Touch 27 06-06-2018 07:37 PM
Wood Inlay Templates-More Possibilities w/ More Layers TarterWoodworking Jigs and Fixtures 10 06-08-2015 07:55 AM
Is this finish good for the toys I'm making? Gweedz The Finishing Touch 8 02-11-2011 02:25 PM
Water based finish over oil based finish? ffjdh The Finishing Touch 10 05-18-2010 06:54 AM
Inlay Guide Bushing and base plate Doyle Portable Routing 3 06-07-2007 10:25 PM
