Best finish to preserve color of Purpleheart - Router Forums
 15Likes
post #1 of 18 (permalink) Old 01-25-2020, 08:03 PM Thread Starter
TWheels's Avatar
Default Best finish to preserve color of Purpleheart
I have some Purpleheart from which I intend to build gift boxes. I have looked into the topic far enough to learn that the deep rich purple color changes over time, especially after exposure to UV, and that the finish needs to be oil based.
My current thought is Minwax 40900000 Wipe-On Poly Finish Clear, as found https://smile.amazon.com/gp/product/...KIKX0DER&psc=1.
Your thoughts?
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #2 of 18 (permalink) Old 01-25-2020, 08:56 PM
keep it out of the light...
protect it from UV exposure...
File Type: pdf Color Stabilization of Wood and Durability Improvement of Wood Coatings.pdf (142.6 KB, 32 views)
post #3 of 18 (permalink) Old 01-25-2020, 10:06 PM
gdonham1's Avatar
First Name: Guy
Unfortunately purpleheart will change to brownish over time no matter what you do. The more UV it gets the more it turns brown. I do not know of any UV inhibitors but you could see if any of the marine finishes have the UV inhibitor.
harrysin and Herb Stoops like this.
gdonham1 is offline
post #4 of 18 (permalink) Old 01-26-2020, 01:15 AM
Marine spar varnish is supposed to have uv inhibitors if that helps. I had some D fir that had beautiful shades of blue and purple in it, the only piece I had ever seen like that but unfortunately it faded out and wasn't so spectacular once it did. It never saw any direct sunlight.
Nickp likes this.
post #5 of 18 (permalink) Old 01-26-2020, 11:30 AM
Nickp's Avatar
First Name: Nick
Varathane and Man o' War make a spar poly...specifically made for external masts and other wood...lots of UV inhibitors...
Epiphanes has the most gloss, if you're looking for that...
Nick
Nickp is offline
post #6 of 18 (permalink) Old 01-26-2020, 11:48 AM
PhilBa's Avatar
First Name: phil
The use of exterior marine finishes makes sense though I'd always thought that UV blockers were to prevent deterioration of the finish itself and not the bleaching of the underlying wood.
By the way, there is a FWW article in #205 (not sure when that was, pre-2009 for sure though) about a multiyear test of exterior finishes. They found that all the consumer "exterior" finishes were basically crap - lasted no more than a year - and that even among the pro finishes only Epifanes went the distance.
Visit my shop website.
PhilBa is offline
post #7 of 18 (permalink) Old 01-26-2020, 11:49 AM
soft and flexible too...
post #8 of 18 (permalink) Old 01-26-2020, 07:49 PM
gdonham1's Avatar
First Name: Guy
Almost all lights emit some UV. So even though you do not put your project in direct sunlight it will always darken over time. Exotics like purpleheart are destined to turn brown over time. You may be able to prolong the beautiful purple/red hue but sooner or later it will turn. Even after the turn to brown it is beautiful.
Stick486 and Herb Stoops like this.
gdonham1 is offline
post #9 of 18 (permalink) Old 01-26-2020, 10:39 PM
I have used Waterbased Poly urethan and it still turns very dark almost black, the finish was supposed to have UV blockers in it.
Herb Stoops is online now
post #10 of 18 (permalink) Old 01-27-2020, 09:40 AM
Nickp's Avatar
First Name: Nick
Herb, the marine finishes seem to work great on the teak on my boat...and it is in the sun all four seasons. After scraping all the old stuff I do a hand sanding then teak oil and then spar finish. If you haven't tried one of the marine spar finishes, grab a test piece/put some on and leave it outdoors through all weather. Not sure how it might work on Purpleheart...
Herb Stoops likes this.
Nick
Nickp is offline
