Wood grain filler - Page 2 - Router Forums
 17Likes
post #11 of 15 (permalink) Old 03-23-2020, 07:38 AM
Bstrom's Avatar
First Name: Brian
Originally Posted by Herb Stoops View Post
That is how I learned how to do it years ago,apply the filler first then the stain. then Shellac, then Varnish.
@Barry747 have you tried the MicroMesh System on the ROS? I put on filler,shellac,and 4 coats of urethane, let dry 4-5 days and then go thru all 9 discs and it looks like a Porche fender. The reason to wait for it to dry is so that heat doesn't soften the finish. Use all 9 discs in succession.
HErb
https://finderscheapers.com/Search.a...0e2c2e6df62dfa
I purchased a full set of the MicroMesh 8-hole ROS pads on eBay ($26 shipped) yesterday - will be curious to see how much it improves finishing, et al. Thanks for the reference...
Common Man Woodworking
Powell, TN
Bstrom is offline
post #12 of 15 (permalink) Old 03-31-2020, 05:32 AM
Laughingdog's Avatar
Hardwood finishers use dust from their floor sanders- the finest dust usually is from the edge sanders- and cut it with enough lacquer thinner for it to smoothly flow and spread it with a metal or hard plastic blade with a swirling type motion to work the goop into the grain from all angles. It is easy to see if you missed a spot. Wear a doo rag so sweat does not drip on your project. You may be able to use other solvents but will need to dry quickly and not swell the wood so not sure that anything but lacquer thinner or equivalent will work hence you might need a respirator....
With a bit of practice you can do a rather clean job like this and a easy wipe down to prep for a coat of finish.
By the way use the dust from sanding the wood you are sealing for a perfect match.
DesertRatTom and Stick486 like this.
Laughingdog is offline
post #13 of 15 (permalink) Old 03-31-2020, 10:01 AM
Hey, Laughingdog; welcome!
Did you mean " lacquer thinner" or lacquer thinned with lacquer thinner?
DaninVan is offline
post #14 of 15 (permalink) Old 04-06-2020, 09:21 AM
lacquer thinner, and yes go fairly lightly with your first coat of sealer whatever it is so you do not drag it out..
post #15 of 15 (permalink) Old 04-06-2020, 12:05 PM
Laughing dog nailed it with purpleheart or any other exotic color wood. Note that Purpleheard often turns brown over time. I'd like to see the finished result. I do love purple heart and often use it for splines, even with the color change. Sealing nelps.
BTW, welcome to the Forum @Laughingdog , whoever you are. Take a moment and fill in the first name on your profile, I don't like calling anyone a dog, even if it is a happy one.
