Help ...Two coats stain in...not as dark as needed... help - Page 3 - Router Forums
 43Likes
post #21 of 29 (permalink) Old 04-28-2020, 04:14 PM Thread Starter
First Name: rp
I kinda convinced her to go with the stain (versus generic white paint)... so yes, she does not care for the beautiful grain... I don't want to go back to paint unless I have no other choice at all.
Stick486 likes this.
123rp123 is offline
post #22 of 29 (permalink) Old 04-28-2020, 04:18 PM
make some sample pieces..
this time use a gel or dye...
post #23 of 29 (permalink) Old 04-28-2020, 04:43 PM
TenGees's Avatar
First Name: Paul
As mentioned already: Sanded too fine = greater variation in how porous the surface is, Oak and birch = very different animals. Many manufacturers spray the tint on and it doesn't get wiped off. I have a bedroom set where you can see the "spray" on the unfinished back and bottom edges. That would be hard to duplicate with a regular stain.
I did a project in pine and couldn't get a dark enough finish to match other pieces. I put Polyshades on top and it came out quite well but the stuff is a horror to put on evenly. The good thing with that product is it stains porous and nonporous parts of the wood. The bad is the difficulty applying it evenly - spraying it would probably be best. Take a look at my TV stand. Did I mention that it's hard to put on evenly?
Stick486 and Herb Stoops like this.
TenGees is offline
post #24 of 29 (permalink) Old 04-28-2020, 11:28 PM Thread Starter
First Name: rp
Default Update ...Two coats stain in...not as dark as needed... help
To update y’all, anti-climatic I guess... did a stain match at Sherwin-Williams; tested on spare pieces of sanded oak and the plywood - wife is “ok” with it. Then sanded down the stained ones down to 120, and applied the new stain. Came out ok.
123rp123 is offline
post #25 of 29 (permalink) Old 04-28-2020, 11:31 PM
good to hear...
post #26 of 29 (permalink) Old 04-28-2020, 11:44 PM
First Name: thomas
Whew!!!
thomas1389 is online now
post #27 of 29 (permalink) Old 04-29-2020, 12:07 AM
Glad you solved that problem and you learned somethings that will last for ever.
Herb Stoops is online now
post #28 of 29 (permalink) Old 04-29-2020, 07:07 AM
Stoneface's Avatar
First Name: Frank
Happy wife, happy life. Good job.
Frank
Herb Stoops likes this.
Frank
Stoneface is offline
post #29 of 29 (permalink) Old 04-30-2020, 07:59 PM
First Name: ben
I have the first edition of "Foolproof Wood Finishes" by Teri Masaschi; a 2nd edition is now available. On page 138, she demonstrated a product called Behlen's raw umber glaze for darkening oak that had already been stained with antique cherry.
bfblack is offline
