Help ...Two coats stain in...not as dark as needed... help - Router Forums
 43Likes
post #1 of 29 (permalink) Old 04-28-2020, 01:02 AM Thread Starter
First Name: rp
Default Two coats stain in...not as dark as needed... help
Hi, Doing my first “big” project ... a dresser/armoire for the missus ... Red Oak for the doors and drawer fronts and maple plywood for the box... some heavy routing for the door panels and drawer fronts done... All in all, a relative newbie...
Coming to the problem...
The wife picked Varathane Red Mahagony by doing a visual comparison of the box color and an existing drawer she wanted to match ... I sanded 80/150/220, cleaned up with Mineral spirits, put some nice conditioner on for a while ...
And in my excitement did not do a test piece first...to make sure the wife likes the color Zzz
Did all the door panels and fronts ... two stains in ... making sure the stain does not stay too long and sticky (as the book says ...
and now the wife says this is not the color she wants... needs to be much darker and redder.
Am I dead now? Are these pieces unsalvagable... is there any way for me to magically darken the stain after two coats (short of sanding down all of the stain)....
Will putting a darker stain on top of the two stains help at all ? Or do I have no choice but to sand it down? If I have to sand it down, how much do I need to go? Should I start with a 80 to remove material and then go back to the finer paper?
Thanks a bunch,
Rama.
123rp123 is offline
post #2 of 29 (permalink) Old 04-28-2020, 02:04 AM
gdonham1's Avatar
First Name: Guy
First of all the color will change with a top coat of poly, lacquer or other varnish. So take some scrap and sand same as project, put stain on and after drying put some finish on it.
If the color is not correct you can put a different stain on but you may never get it perfect because with the original stain and mixing another stain on top you will get something that cannot be duplicated.
So I suggest you finish with what you have because making endless changes will lead to failure. If you decide to put more stain on try a gel stain. You get pretty much what you see with a gel stain. Just remember it will look different with the top coat. So experiment with scrap before you go ahead.
Hopefully you learned the lesson that finishing is 90 percent of the project. People rush the finishing which makes or breaks a project.
gdonham1 is offline
post #3 of 29 (permalink) Old 04-28-2020, 02:06 AM
I think you had better start making samples. Just leave what you have until you get a sample made for what she wants. Take some of the wood scraps from your project and tape off some strips an inch or two apart, Put on a coat on one strip. put 2 coats on another strip. 3 coats on the next and so on. when dry put a coat of finish on everything and see what comes out. If it is not dark enough make another sample using another coat of stain then the finish, maybe have to buy some redder stain to put on top of what you have already put on the cabinet, but do all your experimenting on samples. then when you have found the right color go back and restain the cabinet.
Another tip is write down on a pad what combination you used for each sample, so you can duplicate the one you find is the right one.
Just a suggestion.
RainMan 2.0 and jj777746 like this.
Herb Stoops is offline
post #4 of 29 (permalink) Old 04-28-2020, 02:22 AM Thread Starter
First Name: rp
Thanks folks for the quick reply @gdonham1 , @herb . Really appreciate it.
I still have to do the carcass (which is a maple plywood). For that, I am thinking that will try to recreate the exact steps I do with the currently stained pieces to get them to match (instead of starting from scratch with the 'new' stain I will be hopefully using). Is that a bad idea ?
Should I just start with the new stain directly?
Here is a picture to show how far apart I am. The piece on the left is where I am currently and on chest of drawers on the right is where I need to be.
Thanks,
Rama.
123rp123 is offline
post #5 of 29 (permalink) Old 04-28-2020, 06:56 AM
Stoneface's Avatar
First Name: Frank
I just completed a project with ash. Used Minwax wood conditioner and red mahogany stain. I think we did 3 coats of stain and it was a lot darker. Not sure why your project is so light.
Frank
Frank
Stoneface is offline
post #6 of 29 (permalink) Old 04-28-2020, 07:09 AM
Frank
over sanded the wood and closed the grain/pores...
220 for the initial sanding was too fine... he should have stopped at around 120/150 for the raw wood sanding...
after the staining to desired color/shade and 1st clear coat go w/ the progressive finer sandings between clear coat applications..
for deeper colors use gel stains..
Stick486 is offline
post #7 of 29 (permalink) Old 04-28-2020, 07:17 AM
sreilly's Avatar
First Name: Steve
Thanks,
Rama.
Rama what parts have you done? If it's just the drawer fronts the maybe consider it a lost cause and redo those. Seeing the caucus is the largest percentage of the project you could do your test piece with the stain your wife wanted and either sand down or redo the fronts. It would be a very long shot that you'll get where she wants starting where you are now but you might get lucky or you might just go further away from the target. What will minimize your losses, redo what's done or continue and possibly fail altogether? If you fail will the project have useful life elsewhere. This is a tough lesson but one you'll likely consider each time you get ready to do a new finish procedure. We've all been there at some point in time.
jj777746 likes this.
sreilly is offline
post #8 of 29 (permalink) Old 04-28-2020, 07:50 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
Sorry but polishing wood 101 says you do a test piece, its rule 101, 102, 103, 104, 105, 106.... N
Herb Stoops and jj777746 like this.
neville9999 is offline
post #9 of 29 (permalink) Old 04-28-2020, 08:09 AM
First Name: Art
Using maple on the sides and oak on the front will cause you an even bigger problem. The grain is different and reacts to stain differently. If you put more stain on the oak and let it sit longer it will get a little darker. I would try a different color. You're just going to have to experiment.
Ray Y and Herb Stoops like this.
mgmine is offline
post #10 of 29 (permalink) Old 04-28-2020, 08:33 AM
sreilly's Avatar
First Name: Steve
I think he's admitted to the mistake in his original posting. It's a rookie mistake most likely we've all made but may not admit to. There are maybe a few that escaped this fate but a rare few I suspect. Knowing and admitting it makes a lasting impression unless you're old and forget......now back to the original question...what size screw to use
DaninVan, Roy Drake and jj777746 like this.
sreilly is offline
