Well, this finish is ruined. How to strip it? - Router Forums
 10Likes
post #1 of 17 (permalink) Old 05-18-2020, 09:24 PM Thread Starter
Stokestack's Avatar
First Name: Gavin
Unhappy Well, this finish is ruined. How to strip it?
Hi all.
I bought this cool little tortilla-keeper from a Mayan craftsman in Yucatan 25 years ago. Unfortunately it was left on a stovetop while the oven was on, and the escaping heat ruined the finish. Given the rustic nature of the piece's origin, do you think this is shellac?
What would you suggest for stripping and refinishing? Thanks!
Gavin
Stokestack is offline
post #2 of 17 (permalink) Old 05-18-2020, 09:45 PM
difalkner's Avatar
First Name: David
Test it with some DNA and see if that softens or removes any finish. If it does then it's likely Shellac. If it is Shellac then you can apply new Shellac right on top of that and it will blend right in.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #3 of 17 (permalink) Old 05-19-2020, 01:35 PM
MEBCWD's Avatar
If it is not Shellac then something like this is what I would recommend. https://www.amazon.com/Minwax-673000...9913108&sr=8-1
MEBCWD is offline
post #4 of 17 (permalink) Old 05-20-2020, 01:17 AM
David
what if it's lacquer???
post #5 of 17 (permalink) Old 05-20-2020, 01:25 AM
Recipe for furniture stripper:
Equal parts of acetone, methanol (wood alcohol), methylene chloride and toluene...
soak or paint it on... little goes a long way... wrap/cover the object in a cotton towel and soak the towel... use a white one...
remove the towel and scrape the sludge of w. a plastic putty knife...
don't bother asking what happens if you use a synthetic fabric towel or one that has been dyed...
Always (paint formula, MSDS unknown) consider the probability of the paint being a lead and/or copper base being pretty good... it may fizz/boil/pop/what not a bit.... kinda like mixing Rice Crispies and Alka-Selzer together...
I trust you will be doing this out doors while holding your breath on a breezy day and wearing chemical gloves ...
just never forget you are dealing with unknown paint/finish... do a small segment to start w/ at 1st..
jj777746 and OCEdesigns like this.
post #6 of 17 (permalink) Old 05-20-2020, 02:57 AM Thread Starter
Stokestack's Avatar
First Name: Gavin
Thanks for the suggestions guys.
I put isopropyl alcohol on a paper towel and rubbed the bottom if the thing pretty vigorously and got nothing. There was no visible effect or noticeable softening of the finish. So... not shellac?
The good news is that the inside of the container (where food goes) is fine, but if I can avoid toluene and its ilk on my food-service items that'd be nice. That Minwax stripper says it doesn't work on polyurethane, which I guess this could be. Would a transparent coating contain lead? This was from '95, and granted it's from rural Yucatan but I would not have been worried about lead.
I hate to betray your trust, but the likely scenario is that'll be doing this in the garage of my rental apartment while bathing my hands in and huffing all the required solvents.
What's the next test I should do?
post #7 of 17 (permalink) Old 05-20-2020, 03:18 AM
lacquer thinner...
post #8 of 17 (permalink) Old 05-20-2020, 03:26 AM
denatured and isopropyl are two different animals...
https://pediaa.com/difference-betwee...ropyl-alcohol/
difalkner likes this.
post #9 of 17 (permalink) Old 05-20-2020, 12:25 PM
Bstrom's Avatar
First Name: Brian
[/B]
Let us know if you survive this one - yikes!
Common Man Woodworking
Powell, TN
Bstrom is offline
post #10 of 17 (permalink) Old 05-20-2020, 01:45 PM
it's reverse engineered Formby's....
