Tung Oil + Shellac Mix? - Router Forums
 15Likes
  • 4 Post By Nickp
  • 1 Post By Bstrom
  • 1 Post By Cherryville Chuck
  • 4 Post By Bob Adams
  • 3 Post By Bstrom
  • 1 Post By Bob Adams
  • 1 Post By gdonham1
post #1 of 9 (permalink) Old 05-21-2020, 07:04 PM Thread Starter
Bstrom's Avatar
First Name: Brian
Default Tung Oil + Shellac Mix?
Iíve got some pure Tung Oil Iíd like to Ďfortifyí with something thatíll give a harder finish and a bit of shine.
My guess is that I could add a little clear Shellac (Ratio?) and get a one-off solution.
My logic tells me to just use Tung Oil first and finish with a Shellac or other finish for the tougher finish desired.
Thoughts?
Common Man Woodworking
Powell, TN
Bstrom is offline
post #2 of 9 (permalink) Old 05-21-2020, 07:20 PM
Nickp's Avatar
First Name: Nick
Gonna put my vote in for tung oil first then finish as desired.
Tried a mix on a piece of teak and it didn't seem to absorb as well as oil first then finish...YMMV...
Nick
Nickp is online now
post #3 of 9 (permalink) Old 05-21-2020, 08:00 PM Thread Starter
Bstrom's Avatar
First Name: Brian
Not surprised...Iíll go that route of oil then finish. Easier...
Nickp likes this.
Powell, TN
Bstrom is offline
post #4 of 9 (permalink) Old 05-21-2020, 10:30 PM
Would they be compatible mixed together? Ones oil solvent and the other is alcohol. Just wondering if anyone has tried it before.
Nickp likes this.
post #5 of 9 (permalink) Old 05-21-2020, 10:53 PM
Bob Adams's Avatar
First Name: Bob
Mixed equal parts of BLO(boiled linseed oil), alcohol, and shellac is a common finish used in turning. I keep a jar mixed up by my lathe.
Bob Adams is offline
post #6 of 9 (permalink) Old 05-22-2020, 07:13 AM Thread Starter
Bstrom's Avatar
First Name: Brian
Which confirms that oil and shellac will mix, but the application may not be ideal. The alcohol helps for penetration and dry time and might be what’s needed to go this route, but I’ll adopt an oil-then-finish practice first and see if starting with 1) pure organic Tung Oil, and then 2) use a form of Shellac or Waterlox to achieve desired surface finish. It should accentuate grain pretty nicely and provide a choice of matte to shiny finish options based on number of total coats of finish.
I’m making a short, shallow Cherry box made from a box cutoff for a clock body (No waste here!) that will be a perfect experiment for establishing an oil/finish routine. Will start with pure Tung and then use Waterlox.
Like Arnold said, “I’ll be back!”
Powell, TN
Bstrom is offline
post #7 of 9 (permalink) Old 05-22-2020, 01:32 PM
How do you apply it Bob? Wetted rag?
post #8 of 9 (permalink) Old 05-22-2020, 04:45 PM
Bob Adams's Avatar
First Name: Bob
Yea just a piece of t-shirt. It is a very easy and forgiving finish. If you search youtube for OB Shine Juice there are a lot of videos on the process.
Cherryville Chuck likes this.
post #9 of 9 (permalink) Old 05-23-2020, 01:03 AM
gdonham1's Avatar
First Name: Guy
The trouble with Tung Oil is it takes forever to harden. If you do not have the Tung Oil completely cured anything you put on it will have problems. Shellac is a great sealer and makes wood grain pop. Plus with Shellac first it takes a lot less top coats to get a smooth and good finish.
Just be sure you let the Tung Oil cure before adding more coats or you end up with a sticky mess on the surface.
Nickp likes this.
gdonham1 is offline
