Wiping Varnish Selection - Router Forums
post #1 of 14 (permalink) Old 08-17-2009, 01:23 AM Thread Starter
BigJimAK's Avatar
Default Wiping Varnish Selection
My Son and I are making my own version of Marc Spagnuolo's (The Wood Whisperer) end grain cutting board from padauk and tigerwood. He talks of several finishing options but recommends a 50/50 mix of wiping varnish and mineral spirits. After visiting HD and Lowes and seeing the only product they offer with the "varnish" the offer is Spar Varnish. This didn't sound like something yo cut food on, but I don't know. I scanned their oil based poly cans, suspecting it was varnish-based, but didn't find the word varnish.
I've googled the term and people talk of making wiping varnish by diluting poly and others refer to "wiping varnish (this includes polyurethane)", implying there are verious blends that fall under the wiping varnish name.
He talks about how, after 3-4 minutes of letting the end grain soak this up it may have soaked clear through the 1-1/4" board and how it is not film-building. This sounds like a good finish for a cutting board, protecting the inner wood from water also.
If poly will work and I understand it correctly then it you would dilute poly 50/50 with MS to make wiping varnish and then dilute that 50/50 to get his mix.
This would be a 75% MS / 25% oil-based poly mix. That sounds very dilute but I don't know enough to judge.
I understand that mineral oil can be used as an alternative however he indicated it required regular recoat while mineral oil is only required on this to hide cut marks that may eventually show up.
I could sure use some help here, planning a path forward.
Jim
P.S. There are lots of good free videos on his site:
The Wood Whisperer Woodworking Video Podcast, Blog, and Forum
BigJimAK is offline
post #2 of 14 (permalink) Old 08-17-2009, 09:29 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Many members have, during the time that I've been a member, talked about "wipe on Poly" something that I had never seen, that is until quite recently when I happened to see it in a store. So far I haven't had a chance to try it, but by all accounts it does a great job (I'll let the forum know if it doesn't!)
Harry
harrysin is offline
post #3 of 14 (permalink) Old 08-17-2009, 10:31 AM
dustmaker's Avatar
First Name: Frank
Jim,
I have used the Wipe On Poly that Harry has pointed out...bought it at Lowe's. I am not sure of the mix, but it is definitely thinner than polyurethanes I have used. From your description you may be able to use this right out of the can with no further mixing. It might be worth a look. It is very easy to use with no runs and a very nice finish.
- Frank
Woodworking is more than a hobby.
It is a journey of discovery,
An application of innovation and creativity,
And an opportunity at self improvement.
dustmaker is offline
post #4 of 14 (permalink) Old 08-17-2009, 11:58 AM
Bob N's Avatar
First Name: Bob
Hi Jim,
Based on the desire of soaking thru 1 1/4" of end grain in a few minutes, I would think that the 75-25 mix would be reasonable.
If you are in doubt, why not write to Marc and get him to clarify it for you. He is a very personable guy and I have communicated with him many times over several questions I had. He was always good to take the time to help me.
Bob N is offline
post #5 of 14 (permalink) Old 08-17-2009, 12:24 PM
First Name: jerry
Varnish is made with a resin, a drying(or semi--drying) oil cooked in the absence of oxygen. The resin is usually alkd,the oil usually boiled linseed. Other ingredients such as solvent,driers are added. Polyurethane is an alkd resin varnish with a small amount of urethane resin added. Wiping varnish is simply varnish with enough thinner added to make it easy to apply. If this is to be a working cutting board I would do as the old time butchers did with their blocks a mixture of mineral oil and wax. I have finished a great many cutting boards and unless they were purely decorative I have never used a film forming finish-which varnish is. My best advice would be to use mineral oil or mineral and wax mixed together.
jerry
jerrymayfield is offline
post #6 of 14 (permalink) Old 08-17-2009, 12:46 PM
rwyoung's Avatar
First Name: Rob
It would be easiest to just skip the varnish all together on the cutting board and go with mineral oil or mineral oil + beeswax.
FYI, don't get the mineral oil at the hardware store, they charge too much. Get the generic "house brand" at a chain drug store, it will be cheaper. Just look at the label to be sure it says 100% mineral oil. Similar advice for the beeswax. I found it was more than $2/ounce at the hardware store and $0.95/ounce (1lb block) at Hobby Lobby. YMMV
The last ones I made I just kept slopping on mineral oil until it stopped soaking in. Took about 4 or 5 liberal coats (endgrain cherry & walnut and birch & walnut).
rwyoung is offline
post #7 of 14 (permalink) Old 08-17-2009, 11:35 PM Thread Starter
BigJimAK's Avatar
Originally Posted by Bob View Post
Hi Jim,
Bob,
I think the email to Marc is a great idea, independant of the outcome. If for nothing else just to know what he meant. Your assessment on the mix is very plausable since he made it very clear than the purpose was *not* to build up a film coat.
Jerry & RW,
Mineral Oil or a Mineral Oil wax blend is the next in line. The only reason I was leaning towards the varnish was Marc's claim that it provided better protection and required less maintenance.
Jim
BigJimAK is offline
post #8 of 14 (permalink) Old 08-18-2009, 04:42 AM
xplorx4's Avatar
First Name: Jerry
Lot's of good information here for all of us novices, this is one worth marking for future use. Thanks to everyone for the input.
Lamentations 3:22-23
xplorx4 is offline
post #9 of 14 (permalink) Old 08-19-2009, 04:00 AM
For cutting boards use mineral oil.
ernest plutko is offline
post #10 of 14 (permalink) Old 08-19-2009, 06:33 PM Thread Starter
BigJimAK's Avatar
Bob,
Jerry & RW,
Jim
I emailed Marc Spagnuolo late yesterday and he responded last night. Bob, you were right on! Here's his answer:
"Varnish is a general term for a class of finishes that includes poly. Varnish is nothing more than resin cooked with oil and diluted with mineral spirits. Polyurethane is also a varnish, but its a varnish that is made with polyurethane as the resin.
So your run of the mill polyurethane will work for the purposes of the cutting board. And when it comes to the dilution, I don't get too scientific about it. But I think your math is close enough. 50/50 gives you a wiping formula, then diluting about 50% again gives you the cutting board formula. So I would probably just ballpark it and dilute the full-strength poly about 75% with mineral spirits. That should get you close enough.".
BigJimAK is offline
10" blade selection?? jeep_man Tools and Woodworking 27 04-10-2009 04:57 PM
table saw blade selection blurry Tools and Woodworking 19 03-13-2009 12:12 PM
Newbie Question - Bit Selection - Roundover dabeeler Router Bits - Types and Usage 7 11-24-2007 08:53 PM
Rubbing Out Varnish Gilbear The Finishing Touch 8 05-14-2006 08:34 AM
Thinning varnish jerrymayfield The Finishing Touch 2 12-20-2005 10:48 PM
