Water based finish over oil based finish? - Router Forums
post #1 of 11 (permalink) Old 05-06-2010, 02:00 PM Thread Starter
Default Water based finish over oil based finish?
Can I put a water based finish over an oil based finish? I am currently working on a box with curly maple and purple heart. The curly maple really pops with Arm-R-Seal oil urethane finish, but i have a water based Arm-R-Seal Exterior 450 finish that has UV inhibitors that I wanted to use on the purple maple to protect its color. Can I do a base coat of oil urethane and a water based finish over it?
ffjdh is offline
post #2 of 11 (permalink) Old 05-07-2010, 03:03 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
ffjdh, welcome to the RouterForums. Glad to have you as part of our community.
Dave
the "Doctor"
Dr.Zook is offline
post #3 of 11 (permalink) Old 05-07-2010, 03:47 AM
gav
Country: Croatia
First Name: Gavin
I've always thought the answer to this question is no. Lately though I've been wondering if it could actualy work because they are both urethane and that stuff seems to stick to anything.
I would try it on some scrap if I was you.
gav is offline
post #4 of 11 (permalink) Old 05-07-2010, 11:46 AM
tdublyou's Avatar
First Name: Tim
I too have always been under the impression that oil and water don't mix. But then I remembered that when I had my hardwood floors refinished 10 years ago, they used an oil based stain and a water based poly. The finisher did say that the stain had to completely dry, (3 days as I recall), before he could poly or it would turn green.
Gav's advice of testing on scrap is spot on. It would be tragic to find out the hard way that it doesn't work.
Tim
"The difficult we do immediately... The impossible takes a little longer" - Grandpa
Don't worry about nothin', aint nothin' gonna turn out right anyway" - Dad
tdublyou is offline
post #5 of 11 (permalink) Old 05-07-2010, 11:55 AM
On vacation
First Name: Joe
Good question. No matter what you do any water based finish is going to obscure the grain pattern that you are trying to bring out and preserve. That's just the nature of the beast. It leaves an opaque film. Instead try shellac. It's easy to apply, repairs easily and makes the grain really pop on figured woods. You can finish it with a good quality paste wax rubbed out with 0000 steel wool for a soft sheen.
Here's a box using the same woods as yours finished with boiled linseed oil and shellac...
jmg1017 is offline
post #6 of 11 (permalink) Old 05-11-2010, 01:24 PM Thread Starter
jmg1017, which kind of shellac did you use? The colors on your box turned out nicely. Im thinking I might give the boiled linseed oil and shellac a try.
ffjdh is offline
post #7 of 11 (permalink) Old 05-11-2010, 02:39 PM
On vacation
First Name: Joe
Here's a link to the site I use.
J.E. Moser's SEEDLAC
The Super Blonde grade is the clearest. Buy the flakes and you can control the "cut" That's the amount of flakes in lbs, to the amount of solvent in gallons. I use a 2lb cut. I usually mix a quart at a time. It sounds complicated but it's not. The instructions for mixing come with the flakes. Keep them cool and dry and they last a long time, then just mix what you need for a project. You can also by it premixed.
If you Google "Jeff Jewitt" you can find a wealth of information about mixing and applying shellac. Once you try it you won't go back.
jmg1017 is offline
post #8 of 11 (permalink) Old 05-12-2010, 11:02 AM
First Name: jerry
As I have often said if shellac were discovered today it would be called a wonder(super) finish. It is also color fast.
Regards
Jerry
jerrymayfield is offline
post #9 of 11 (permalink) Old 05-15-2010, 10:54 PM Thread Starter
What kind of solvent do you guys recommend to use with the super blonde? I guess the kind they recommend on that site isn't allowed in CA.
ffjdh is offline
post #10 of 11 (permalink) Old 05-15-2010, 10:58 PM Thread Starter
Also how many coats of linseed oil did you use? Ive used linseed oil on ax handles before, but never for any of my woodworking projects
ffjdh is offline
Oil based brush on amber poly and water based acrylic paint ? Duane867 The Finishing Touch 6 01-14-2010 06:56 PM
Help: Hot Water System Gone Wild morgantruce DIY and Renovation 8 12-27-2009 08:40 AM
finish to use over water based stain? rstermer The Finishing Touch 10 09-04-2008 10:01 AM
oil or water based polyurethane???? jer760 The Finishing Touch 1 02-07-2008 12:59 PM
