How to sand a groove? - Router Forums
post #1 of 28 (permalink) Old 10-24-2011, 04:24 PM Thread Starter
Default How to sand a groove?
I have been trying to find an easier way to sand grooves! I have a core box bit that I use to create juice grooves in cutting boards. I currently am hand sanding these using steel wool and a rubber contour sanding grips. The problem is, it takes forever if I use actual sand paper. Steel wool works better but it also wears out quickly. Both methods take a lot of work to create a nice finish.
Are you guys aware of any sort of sanding bit that can be used in a dremel tool? The problem I have with most of these bits is that they are to harsh and want to remove a lot of wood or end up leaving burn marks. I am thinking along the lines of a polished finish.
Otherwise I would love to hear how other people sand in situations like this!
bradleyjere is offline
post #2 of 28 (permalink) Old 10-24-2011, 06:01 PM
You could use a dowel the same diameter as your grooves. Wrap the sandpaper around the dowel. Then you can use it as a round sanding block. The contour sanding pads for these types of situations are the most popular way of doing this. I see you tried this method. Maybe take a second light pass with the router to clean it up so you don't have as much sanding.
http://www.woodcraft.com/Family/2005...ding-Pads.aspx
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 28 (permalink) Old 10-24-2011, 07:04 PM
Sanding Mop - YouTube
.: Stockroom Supply :. Sandpaper | Stockroom Supply
post #4 of 28 (permalink) Old 10-24-2011, 09:06 PM
xplorx4's Avatar
First Name: Jerry
Thanks BJ, nice to know.
Lamentations 3:22-23
xplorx4 is offline
post #5 of 28 (permalink) Old 10-25-2011, 02:36 AM
Porter Cable makes an excellent profile sander with an optional dust collection hose kit.(It should be standard!) If you have a large amount to sand this is the way to go.
post #6 of 28 (permalink) Old 10-25-2011, 06:42 AM
paduke's Avatar
I think the profile sander has been discontinued
paduke is offline
post #7 of 28 (permalink) Old 10-25-2011, 08:03 AM
OPG3's Avatar
First Name: Otis
Unless you're going to be making huge numbers of these, sandpaper on a dowel is the best way to go. I do stuff like this daily and that is the best method I know of. OPG3
OPG3 is offline
post #8 of 28 (permalink) Old 10-25-2011, 10:06 AM Thread Starter
Thanks for all the ideas guys!!! I will probably try the dowel solution first since it is not expensive and pretty simple. I might mess around with making a dowel that I can attach to my drill. Not sure if it will work but it's worth a try.
Also, I ended up coming across another solution similar to the sanding mops. Maybe a little more controlled that that though.
Professional Sand-O-Flex Contour Sander - Woodcraft.com
Thanks again!!!
Brad
post #9 of 28 (permalink) Old 10-25-2011, 10:18 AM
Be careful if using the sanding mops. You can easily round over the edges of your grooves ruining the profile.
Whittier, CA.
jlord is offline
post #10 of 28 (permalink) Old 10-25-2011, 10:25 AM
HI Brad
Pull out some 3/8" dowel rod ,cut off a 6" long stick, take it to the band saw and cut a slot in it, about 2" long, slip the sand paper in the slot with a little masking tape to hold the paper in place and then chuck it up in your drill.." called a flap sander"
Thanks again!!!
Brad
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Wedge tonuge and groove (CMT 855.510.11) Drew Eckhardt Router Bits - Types and Usage 2 01-23-2009 09:39 PM
Cutting a curved groove rsmtg New Member Introductions 3 09-25-2008 10:56 PM
Tongue and groove bits archer_456 General Routing 4 02-18-2005 05:51 AM
Forgot a groove - now what? Scotty General Routing 9 10-23-2004 02:35 PM
