DIY wiping varnish formula - Router Forums
post #1 of 18 (permalink) Old 09-16-2012, 03:01 AM Thread Starter
First Name: Mark
Default DIY wiping varnish formula
Hi all, looking for a little clarification on 2 points.
Some time back I ran accross a reference to making wiping varnish by thinning polyurethane 50%.
I recently did this using the thinners the manufacturer recommended, mineral turpentine. I've done a couple of jobs using both satin and gloss polyurethane with good results although the gloss had a slightly more subdued finish than I expected.
I then found that the original instructions I'd seen said to thin with mineral spirits.
First of all I can't say I've seen mineral spirits in the shops, not that I was looking, is it called something else down here ?
Secondly, before I run out and start adding to my collection of chemicals, can someone please tell me what practical difference, if any, there would be by using turps or mineral spirits.
Mark
Mdawson is offline
post #2 of 18 (permalink) Old 09-16-2012, 03:35 AM
biloxi tom's Avatar
First Name: tom
there are 2 differences mineral spirits (also called mineral turps, but really isn't as all turpentine is made for tree sap usually pine) if you use too much mineral spirits the binders in your paint varnish whatever won't work right. this might (i am not sure) because spirits dry way faster than turps. which is the 2nd thing that I know about the 2 is the drying time difference. this probably isn't much help but I tried to remember what my dad said about the 2 and this is the only things that stick out in my mind. later biloxi tom
"DO NOT have a good day, have a wild and wonderful one!
biloxi tom is offline
post #3 of 18 (permalink) Old 09-16-2012, 07:12 AM
First Name: David
Default Turps vs Spirits
Don't know about "down there" but up here we have real turpentine (tree sap product) and mineral spirits (frequently marketed as Varsol. It's a petroleum product.) As far as I know Varsol and mineral spirits are the same thing (I could be wrong, and frequently am) There is also paint thinner which is what I think you are thinking of re: mineral spirits. If this makes any sense.
I would stay away from artificial turpentine.
Good luck, David
Skyewalker is offline
post #4 of 18 (permalink) Old 09-16-2012, 07:16 AM
Wildwood's Avatar
Country: South Africa
First Name: Rob
Hi Mark - to get really confused, do a Google search! For what it's worth, here in SA we have Mineral Turpentine, which I suspect is the same as Mineral Spirits, a petroleum distillate, and then we have Genuine Turpentine, which is a lot more expensive being a tree extract product, and used extensively by artists using oil paints. This might be worth trying, to achieve a better finish.
Rob
Wildwood is offline
post #5 of 18 (permalink) Old 09-16-2012, 07:23 AM
Wildwood's Avatar
First Name: Rob
Hi again Mark - here is an old thread along the same lines, emanating from your part of the world.
Mineral spirits [Archive] - Woodwork Forums
By the way, how did you guys manage to beat us a week ago?
Rob
Wildwood is offline
post #6 of 18 (permalink) Old 09-16-2012, 09:18 AM
First Name: Mark
Aloha Mark,
I could be wrong but turps is a product of distilling pine(? So a natural product) and mlneral spiirits is from distilling also but things from ( under ground, ect: oil, petrol.) Hope I remembered it right. Aloha from Oahu, from Mark, kohalabeeman
kohalabeeman is offline
post #7 of 18 (permalink) Old 09-16-2012, 09:37 AM
Gene Howe's Avatar
First Name: Gene
You might try mixing with boiled linseed oil. It works well for me as a wiping varnish. I've also used a product called Watco to mix with both varnish or poly. Also works well.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #8 of 18 (permalink) Old 09-16-2012, 09:58 AM
rwl7532's Avatar
First Name: Ralph
Use Wikipedia:
Turpentine - Wikipedia, the free encyclopedia
White spirit - Wikipedia, the free encyclopedia
Paint thinner - Wikipedia, the free encyclopedia
  • Accident free since 10/27/12 at 3:58 pm.
  • Cursing free since 10/27/12 at 3:59 pm.
  • ...it happened in Everett, WA USA
rwl7532 is offline
post #9 of 18 (permalink) Old 09-16-2012, 10:55 AM
giradman's Avatar
First Name: Dave
Hi Mark - hopefully, the links have clarified the differences in terminology used in various parts of the world for these products!
I've used 2 'homemade' clear finishes over the years, i.e. the 'wiping varnish' concoction using 1/2 poly (or varnish) & 1/2 solvent (mineral spirits or naphtha, the latter another petroleum/gas distillate) - I prefer the naphtha for its faster drying time, but a personal choice.
The other uses the 'thirds rule', i.e. 1/3 poly (or varnish), 1/3 MS or naphtha, and 1/3 BLO (boiled linseed oil, which BTW is NOT boiled) - this is a common formula that has been around for years. If I'm doing a 'wipe on' clear finish w/ this material, I would typically use it for just the first coat (not sure the BLO penetrates much w/ additional coats & I don't like rags w/ BLO laying around the shop!) and then switch to the simpler wiping finish.
Good luck w/ your projects - Dave
giradman is offline
post #10 of 18 (permalink) Old 09-16-2012, 04:17 PM
First Name: Peter
I use the thirds method with a third each of poly, boiled linseed oil and 'Pure Gum Turpentine'. Lovely smell and available in most hardware stores in Australia - even B.... 's. Nothing critical in the proportions - just pour equal amounts into a jar. Dries fairly quickly - about 15 minutes.
Aragocom is offline
Wiping Varnish Selection BigJimAK The Finishing Touch 13 09-17-2012 01:49 AM
DIY Overhead router akkerwillie General Routing 1 03-22-2012 01:41 PM
