Heat proof finishes - Router Forums
post #1 of 15 (permalink) Old 10-01-2012, 11:57 AM Thread Starter
First Name: Ben
Default Heat proof finishes
Hi all --
My wife has come home with her latest garage sale finds. They are a set of cast iron oval shaped fry pans with matching wooden serving platters. For non-Texans the idea is to serve your meal smoking hot from the oven in the fry pan. The pan in brought to the table on the wooden serving platter. You have to be darned careful not to burn your self eating directly from the frying pan.
This part of Texan folk lore not withstanding, my question follows.
I wish to strip, sand and refinish the wooden serving platters. Can anyone suggest a finish that will stand up the hot fry pan?
Ben
Forest Reduction Study Group
Ben in Cypress Texas is offline
post #2 of 15 (permalink) Old 10-01-2012, 09:25 PM
They may be better off with no finish at all. Certainly not any of the varnishes or urethanes, they are basically liquid plastics. Maybe some oils might work but if the pan is hot enough it might make the oil finish smoke and that wouldn't do much for your appetite.
post #3 of 15 (permalink) Old 10-01-2012, 09:28 PM
Harrison67's Avatar
First Name: Harrison
Originally Posted by Ben in Cypress Texas View Post
Hi all --
Ben
The only thing I can think of would be stove paint, like Henry Ford said; it only comes in black.....as far as I know. I use it on the steel flue for my wood furnace.
Harrison
Harrison67 is offline
post #4 of 15 (permalink) Old 10-02-2012, 06:23 AM
JOAT's Avatar
First Name: Theo
Exhaust manifold paint comes in various colors, and they're rated at something over 1,000 degrees as I recall. Any auto parts store would have them. I'd try them on scrap first.
JOAT is offline
post #5 of 15 (permalink) Old 10-02-2012, 08:05 AM
First Name: Richard
Send a message via Skype™ to rwbaker
Do yourself a favor and either go with bare wood as suggested or use walnut oil. The pan should be cast iron ( for authenticity) and you may wish to route a slight indention to keep a hot pan from sliding. Being forced to move to Texas myself I understand your concerns, but remember that Texas is not a state but a separate country that never grew-up. I did it to be close to my grand-daughter so the eccentricities even out.
PS - you can always glue ceramic to it
rwbaker is offline
post #6 of 15 (permalink) Old 10-02-2012, 08:41 AM
Contributor of the Month
OPG3's Avatar
First Name: Otis
Don't use Cherry Wood - it burns quite easily! Cedars & Pines would likely have the same problem. The [above] recommended ceramic is, in my opinion; an excellent suggestion!
OPG3
Tweak everything!
OPG3 is offline
post #7 of 15 (permalink) Old 10-02-2012, 09:36 AM
bobbotron's Avatar
First Name: Rob
I think with these kind of boards, you just have to deal with the resting area getting a bit scorched. I think a light oiling would be best. It'll get burnt in, but wont get too messy or stick to the pan in the process. Maybe oil it, let it cure for a few days and then stick the hot pan on it a few times before you're cooking with it, in case it does smoke or smell bad as the oil burns off.
bobbotron is offline
post #8 of 15 (permalink) Old 10-02-2012, 10:50 AM Thread Starter
First Name: Ben
Thank you all (that's Y'all) for your responses and good ideas.
Ben
post #9 of 15 (permalink) Old 10-02-2012, 05:03 PM
Ben; how about routing out some grooves and inserting brass or aluminum square stock, sicking proud by maybe a 1/16" +
Maybe 1/4" maximum, spaced about an 1" part, length determined by the size of the serving board.
That'll keep the heat away from the wood.
DaninVan is online now
post #10 of 15 (permalink) Old 10-02-2012, 07:58 PM Thread Starter
First Name: Ben
Good idea!!
thanks
ben
Would our academic members like to comment harrysin Lobby 2096 01-30-2015 01:54 PM
Shop heat and air curiousgeorge Lobby 9 07-23-2012 02:35 PM
How do you heat your wood shop? Jack Wilson Lobby 23 04-24-2011 08:00 AM
Painting signs and other finishes. nightwatch New Member Introductions 6 03-16-2009 05:42 AM
Trying to beat the heat Glenmore Lobby 7 07-16-2008 01:14 PM
