Staining Maple - Router Forums
post #1 of 13 (permalink) Old 11-14-2012, 12:12 PM Thread Starter
First Name: David
Default Staining Maple
I am not satisfied with the stained finish I get on maple. I use a sealer (very dilute shellac) to eliminate blotchiness, but then it is very difficult to get any decent penetration of the stain that follows.
Any suggestions?
jdnordstrom2 is offline
post #2 of 13 (permalink) Old 11-15-2012, 08:38 AM
Bradleytavares's Avatar
First Name: Bradley
I'm building a project with Maple and looking foreword to reading comments on this topic.
Bradleytavares is offline
post #3 of 13 (permalink) Old 11-15-2012, 09:31 AM
First Name: del
are you using a stain ? or dye?
del schisler
port st. lucie, florida
del schisler is offline
post #4 of 13 (permalink) Old 11-15-2012, 09:46 AM
First Name: Chris
Chris Curl is offline
post #5 of 13 (permalink) Old 11-15-2012, 11:34 AM Thread Starter
First Name: David
Stain
post #6 of 13 (permalink) Old 11-15-2012, 04:24 PM
First Name: Keith
I use maple a good bit and I have good luck staining it without any sealer.I sand it from 100 grit to 180 grit then I stain it with 2 coats of Old Master Stain ( penetrating stain).Brands of stain do make a differance.
Woodshaper67 is offline
post #7 of 13 (permalink) Old 12-12-2013, 07:31 PM
IC31's Avatar
First Name: Dave W
I'm bringing this oldie back to the top and hope others a year plus later might have a better feel for how maple can be successfully stained. I went through the attachments in Chris's post and am just about as confused as before. It's too late for my current project, a simple little table for my wife's laptop, and to be used along side of her chair. The maple I picked out had nice grain figuration, but they were pretty much washed out after applying 3 coat of Minwax Golden Oak as I have virtually always used and had always had decent luck - even with maple. I did use a water based product instead on a TV cabinet, but the drool down the side of the can have obiterated the product name. First of all, has Minwax to anyone's knowledge become, for no better word, weaker as far as color and penetration? Some really old cans of other Minwax color stains I have that are still good smell stronger and seemed to penetrate some scrap pieces of the same maple. I could drag out my spray gun and put some lacquer on the wood surface instead, I just don't care for the poor resistance to scratches on a piece of furniture nor do I have a good place to spray paint much of the year - too cold/too hot in the garage
Dave W
Quando omni flunkus, moritati (When all else fails, play dead - R Green)
IC31 is online now
post #8 of 13 (permalink) Old 12-12-2013, 09:42 PM
boogalee's Avatar
First Name: Al
Hi Dave
View this video by Charles Neil. but remember he produces the pre stain.
Al
boogalee is online now
post #9 of 13 (permalink) Old 12-13-2013, 06:36 AM
IC31's Avatar
First Name: Dave W
Originally Posted by boogalee View Post
Hi Dave
Al
Thanks Al. I watched as much of that 23 minutes of Charles Neil as I could stand - he sounds/looks like a 2:00 AM infomercial. I dug further into the 'net to see if others had reviewed it and for the most part it got decent or better discussions but with the caveat from a few that it did cover some of the wood natural figuration. Since I do like working with maple, poplar and pine, the three woods most mentioned will probably give it a try next time. I just wish it was easier/less expensive to source then $19 plus shipping.
Dave W
IC31 is online now
post #10 of 13 (permalink) Old 12-13-2013, 07:01 AM
First Name: del
i use the blotch control all the time, on maple you may have to stain a couple time's ? i use it on cherry , or on all the wood's , it work's very well , have used it sence it came out, i guess if you don't like his voice turn off sound, and watch a silent movie, that what it used to be, in the olden days'
del schisler
Staining Maple jdnordstrom2 New Member Introductions 2 11-13-2012 04:10 PM
maple for luthiers istracpsboss Wood Species 5 11-11-2011 02:20 PM
Maple dovetails Robert7 Portable Routing 6 05-06-2010 10:14 PM
maple drasbell Wood Species 6 10-29-2009 09:03 AM
