Paint over poly - Router Forums
post #1 of 9 (permalink) Old 12-29-2012, 03:50 PM Thread Starter
First Name: richard
Default Paint over poly
A few years ago, I built a two door cabinet and finished it with minwax rub in poly, about five coats. I now want to paint it black. Can I just prime with a latex primer, then paint, with no fear of peeling?
richtink is offline
post #2 of 9 (permalink) Old 12-29-2012, 06:11 PM
First Name: Duane
I have always heard that after it totally cures, even poly won't stick to poly. An isolation coat of shellac, maybe? I'd scuff sand it first, though.
Dmeadows is offline
post #3 of 9 (permalink) Old 12-29-2012, 08:42 PM Thread Starter
First Name: richard
google confirms not an easy process as I was hoping.
How To Paint Over Polyurethane
richtink is offline
post #4 of 9 (permalink) Old 12-29-2012, 08:47 PM
DaninVan is offline
post #5 of 9 (permalink) Old 12-30-2012, 06:55 AM
PawPawRay's Avatar
First Name: Ray
You will have to scuff it with sandpaper then use Kilz or Zinnsers 123 then you can paint over the primer.
PawPawRay is offline
post #6 of 9 (permalink) Old 12-30-2012, 08:08 AM
First Name: Richard
Send a message via Skype™ to rwbaker
Use a shellac primer (tinted) after a light sanding of the cabinet doors - doing the same thing in Mahogany. Shellac primer is twice the price. Home Depot and Wal-Mart are the same price and a quart goes a long way. Do not try to spray it. The other option is to take the doors to a auto body shop and sprayed with an epoxy - probably cheaper to buy new cabinets.
Good luck,
Baker
rwbaker is offline
post #7 of 9 (permalink) Old 12-30-2012, 02:17 PM
First Name: Gene
Question What is a good Vertical Glue
Happy New Year to All.
I have a few long vertical joints to make. All need to be glued and clamped at the same time. All the glues I've tried, all want to run down and drip off by the time I get ready to clamp. Then after all is clamped the whole assembly then will be screwed. All the big box stores say Liquid Nails or a Lock Tite type glue. I've just never been a big fan of that type of glue. I know if anyone knows it would be one of you guys. Thanks a Bunch.
LiLRdWgn is offline
post #8 of 9 (permalink) Old 12-30-2012, 03:08 PM
Gene; the advantages of the construction type (Liquid Nails, PL etc) is that they work on wet lumber, in the cold, and under really adverse conditions. They're intended for framing construction, not cabinetry.
They eliminate floor squeaking when applied to subfloor-joist contact at the time of assembly (and even after the fact on old floors, when squeezed into the points of contact). They also add substantially to the structural strength of sheer walls; the walls can't wrack.
If I was building in a tornado prone area, I'd use that stuff on everything!
DaninVan is offline
post #9 of 9 (permalink) Old 12-31-2012, 06:19 AM
First Name: Gene
Thanks Dan, I know I put this question in the wrong place. I released it after I hit the post button. I'm still looking for a glue that don't run off. Thanks Again.
LiLRdWgn is offline
Paint over paint The Warthog The Finishing Touch 3 09-29-2011 12:55 AM
My Step-Back Cupboard Build rwyoung Project Plans and How To 53 11-13-2010 10:22 AM
Oil based brush on amber poly and water based acrylic paint ? Duane867 The Finishing Touch 6 01-14-2010 05:56 PM
Paint or Poly? -Sam- Tools and Woodworking 6 02-22-2005 03:55 PM
