Cabot Sanding Sealer - Router Forums
post #1 of 4 (permalink) Old 01-01-2013, 12:14 PM Thread Starter
Marco's Avatar
Default Cabot Sanding Sealer
The short version is stay away from Cabot's Sanding Sealer..... Amazon.com: Valspar 144.0008065.005 Cabot Interior Quick Dry Sanding Sealer & Finish: Home Improvement It gums up and leaves a mess for you to clean up .........and then good luck trying to salvage your work.
Amazon is the only sight where it also lists it also as a finish.......... I tried it a year or 2 ago trying to make polar not blotch, that didn't turn out well. This time I used it to seal only and it was a train wreck.
Galatians 5:13
Marco is offline
post #2 of 4 (permalink) Old 01-02-2013, 08:41 AM
First Name: Richard
Send a message via Skype™ to rwbaker
Thanks Marco for this information - please comment about this on the amazon website to warn as many as possible. General Finishes makes one that works and I have had good luck with a slow wipe down of MEK or acetone prior to staining in order to prevent blotches. If you use the water method of grain raising prior to final sanding this will reduce the drying time before final sanding. Remember, the fumes are flammable and deadly so wear gloves and have a slight breeze to carry the fumes away from you or use a vent fan with a carbon filter.
good luck,
Baker
rwbaker is offline
post #3 of 4 (permalink) Old 01-02-2013, 05:42 PM Thread Starter
Marco's Avatar
Done... I had this Cabot sealer and was going to use it followed by a clear finish so figured it would be fine.... I should have used Charle's Neals sealer... which I did after I got that junk of the wood
Galatians 5:13
Marco is offline
post #4 of 4 (permalink) Old 02-20-2013, 10:26 PM
jeffjacob's Avatar
First Name: Jeff
hey thanx for sharing the information.
jeffjacob is offline
Sanding BernieW Woodturning and Lathes 9 12-29-2011 07:01 PM
Finishing the way I see it! by Derek Willis. derek willis Woodworking Articles 0 02-28-2011 08:44 AM
Sanding sealer ? dwayne423 Lobby 15 12-16-2009 03:33 AM
Sanding Tips pmspirito Tools and Woodworking 7 05-22-2009 08:49 AM
Sanding Sealer - What is it? Thrifty Tool Guy The Finishing Touch 11 02-21-2009 08:28 AM
