What am I doing wrong!?? - Router Forums
post #1 of 11 (permalink) Old 01-24-2013, 02:58 AM Thread Starter
Country: Malta
First Name: Joseph
Default What am I doing wrong!??
Now I have these American walnut vernier wardrobe doors and sides, 7 pieces in total.
I sprayed them with a basecoat and then applied 2 finishes over that only to re-apply another finish as the end result was still quite rough and not smooth.
End result....same rough finish. This is not my first time spraying and this has never happened before!
I used the same mix as I did before..1 part thinner, 1 part hardener and 2 parts finish/basecoat.
The spray is cleaned after every use and the mix is filtered befor going in the gun and also whilst spraying.
I cannot understand what am I doing wrong.
Any suggestions, maybe anyone was unlucky like I am now some time earlier????
Mosti is offline
post #2 of 11 (permalink) Old 01-24-2013, 06:06 AM
rrj
rrj's Avatar
First Name: Bob
Need to tell us more about your prep, base coat material, finish coat material and what you did between coats?
Bob
Lake Geneva, WI
rrj is offline
post #3 of 11 (permalink) Old 01-24-2013, 06:50 AM
First Name: Art
It sounds like an adjustment or distance problem , it sounds like the finish is going on dry.
mgmine is offline
post #4 of 11 (permalink) Old 01-24-2013, 08:55 AM
First Name: dave
Could overspray be drifting down? Are you fully "wetting out"?
dave brewer is offline
post #5 of 11 (permalink) Old 01-24-2013, 09:55 AM
First Name: Mark
Alhala from Oahu, q1: did you lightly sand between each coat of sealer and finsh? Follow each's sanding with a rubbing of 'tack' cloth- q2: is surface of materal under your walnut veneer smooth? if ņot it could be telegraghing thru your veneer. Those would be my best quesses from this veiw. Hope you enjoy what youyou produce . Aloha! Mark
kohalabeeman is offline
post #6 of 11 (permalink) Old 01-24-2013, 10:07 AM Thread Starter
Country: Malta
First Name: Joseph
Yes I am sanding. Overspray is not the issue.
Mosti is offline
post #7 of 11 (permalink) Old 01-24-2013, 01:20 PM
Joseph, changes in the temperature or humidity when spraying could be part of the problem. Perhaps water in your air supply? This is a tough question to answer.
post #8 of 11 (permalink) Old 01-24-2013, 01:34 PM
First Name: dave
Taunton's Complete Illustrated guide to Finishing will at least take some of the guesswork out of what I feel is the most difficult part of woodworking. It is written by Jeff Jewitt.
post #9 of 11 (permalink) Old 01-24-2013, 03:33 PM
First Name: Gerry
Is it possible that you are spraying a little too far from the surface and the mist is partially hardening befor it hits the surface? Try out your spraying on some scraps, to see if you can get the desired finish by altering your spraying distance. If altering the spraying distance does not improve the finish it is possible that the finish you are using could be defective or too old. I am making the assumption that your sprying environment is dust free, and you are wiping the surface down with a tack cloth to remove any possible surface dust. Another thought just occurred. Does your compressor have a water trap/filter system?
Gerry
Gerry Kiernan is offline
post #10 of 11 (permalink) Old 03-26-2013, 12:41 AM
Did you get your problem resolved? Are you spraying Poly by chance? You have any pictures?
Thanks Rick
Smokeem is offline
What Did I Do Wrong dustywoodworker Table-mounted Routing 16 02-22-2012 09:12 AM
I think I'm on the wrong forum allears New Member Introductions 16 02-03-2011 04:20 AM
tear out - what went wrong ? jkristia General Routing 12 06-16-2010 07:05 PM
What's wrong with this box? brucio Wood Scrolling 12 04-20-2009 07:37 AM
Making a template, where did I go wrong? Thom2 Guide Bushings and Templates 10 08-09-2007 07:54 AM
