Painting a logo, sealing for sea use - Router Forums
post #1 of 3 (permalink) Old 06-28-2013, 03:27 PM Thread Starter
Default Painting a logo, sealing for sea use
I'm currently working on a small woodworking project that includes some stuff I've never done before.
I want to paint a small logo onto a wooden box, then seal it/protect it for use on a boat. This would be given as a gift to a relative who does a lot of sea sailing, and the box would be a nice item to have below deck (not directly in contact with seawater).
The logo would be a single color, probably black, custom designed and around 2 inches square in size. There would be a little bit of detail involved, so I thought a stencil might be the best way to go, but I've never done that before. Is there a simple stencil system that would work well for my purposes, or is there a better way to go?
The second thing I'm wondering about is the best way to seal up the wood after I put the logo on. I've done some work with polyeurethane, and I would guess that would be OK, but I'd love to hear any other suggestions.
Thanks!
JohnFleming is offline
post #2 of 3 (permalink) Old 06-28-2013, 04:59 PM
Gaffboat's Avatar
First Name: Oliver
I liked to use Sikkens Cetol Marine wood finish on my sailboat. It is a synthetic that is applies with a brush and needs no sanding between coats. It gives bare wood an orange-ish brown cast that I found pleasant. It is formulated for marine use above the waterline for those who want low-maintenance brightwork.
For the logo you could make a reverse-image laser printout of your artwork and transfer it to the wood with an iron. Then use that as guide for routing or just hand painting the logo. A stencil seems like a lot of work that won't give you crisp edges unless you get a sign maker to cut you a vinyl stencil. Dan (L Town Graphics) could probably advise better on that technique.
Gaffboat is offline
post #3 of 3 (permalink) Old 06-28-2013, 10:14 PM Thread Starter
That's great advice on both fronts. Thanks very much.
Woodworking business logo EnRouteWoodcrafts Lobby 8 10-29-2012 08:15 PM
carving a logo on a desk set nvenezia CNC Routing 8 05-28-2012 08:20 PM
Company Logo :) hands made for wood Tools and Woodworking 5 02-10-2011 01:33 AM
Painting Pressure treated wood kp91 The Finishing Touch 9 09-05-2008 10:26 PM
