Inky stains - Router Forums
post #1 of 6 (permalink) Old 07-22-2013, 11:16 AM Thread Starter
Default Inky stains
Hi I've been doing some repairs to an old mahogany book stand my wife inherited. But it has some ink stains on the front - think fountain pen ink. Any one have a suggestion for removing the stains and refinishing? Thanks in advance
John
Fraise is offline
post #2 of 6 (permalink) Old 07-22-2013, 11:35 AM
Semipro's Avatar
First Name: John_*
John
You might want to try nail polish remove on a cotton ball to remove ink
Semipro is online now
post #3 of 6 (permalink) Old 07-22-2013, 12:28 PM
MAFoElffen's Avatar
First wipe it off with denatured alcohol to clean the finished surface. Then alternate wiping it with mineral spirits and sanding. If any remains after getting the finish off, then put undeleted bleach on it and rinse off after about 10 minutes with a TSP solution.
Alternate method- Bix Original Varnish and Stain Stripper. Mostly Acetone, plus other. Nail polish remover has Acetone, but you can use on your hands. Bix is very strong and corrosive, requiring gloves. After you get the finish off, dilute some Bix with water and scrub with coarse steel wool, that will loosen the stain in the grain. After it is well wetted... If it has a brown stain in the wood, scrub with white vinegar to flush the stain out of the grain. If a reddish stain, use bleach. To rinse and stabilize it, scrub and rinse with a TSP solution..
Less sanding on method 2. I use method 2 if there is a veneer and you don't want to sand through the veneer trying to lift the finish and stain. Ink will dissolve with either mineral spirits or acetone, but you want to dissolve and lift it out (flush it) instead of dissolving it and pushing it further into the grain... I use those 2 methods if it ink that is set into wood.
If it were fresh ink on finished wood, dishwashing soap works pretty well at stabilizing the ink and suspending it while trying to remove it.
If it were fresh ink on unfinished wood, then I use a baking soda and water paste and scrub it down. Baking soda is really abrasive stuff and will help stabilize the ink while trying to get it out.. Using acetone on unfinished wood to try to get ink out, just seems to dissolve the ink and pushes it further down into the wood grain.
Just my experiences on that and refinishing..
MAFoElffen is offline
post #4 of 6 (permalink) Old 07-22-2013, 12:54 PM
Contributor of the Month
OPG3's Avatar
First Name: Otis
WOW! Mikey has a lot of tricks up his sleeve. I had problems when trying to clamp live squid with Quercus-Ferrous clamps, the ink got on the oak. We used sand blasting with pellets of argon gas and it worked okay, but Mike's ideas are much better!
Otis Guillebeau - continuously prototyping useless projects, and on occasion cool stuff!
OPG3
Tweak everything!
OPG3 is offline
post #5 of 6 (permalink) Old 07-22-2013, 12:58 PM
OPG3's Avatar
First Name: Otis
Oops! We had Alphabet Soup for lunch and my grandson had sneezed the letters S&T onto my glasses - I thought it said "STinky stain removal" - MY BAD.
Definitely use Mike's suggestion, he is quite smart.
Otis
OPG3
Tweak everything!
OPG3 is offline
post #6 of 6 (permalink) Old 07-23-2013, 05:59 AM Thread Starter
Thanks all. Both advice and humour!
Fraise is offline
Aluminum top stains wood... Nickp Table-mounted Routing 11 12-12-2012 05:40 AM
wood stains to give appearance of Elm TWheels The Finishing Touch 5 08-08-2008 02:10 PM
stacker stick stains John B Table-mounted Routing 2 01-20-2005 04:02 PM
