Finishing Maple/Analine Dye - Router Forums
post #1 of 3 (permalink) Old 08-08-2013, 05:43 PM Thread Starter
First Name: Chad
Default Finishing Maple/Analine Dye
I'm planning a new desk for my wife, we've settled on and purchased a sheet of maple plywood for the majority of the construction. Most of my experience so far has been with softwoods but I've made a few projects with cherry, which has proved to be very difficult to stain so I've just used wipe-on poly to both raise the grain and finish it. I've read that maple has similar characteristics.
In my research so far I've heard it suggested from a reliable Youtube source to sand it rough, say 120, and then stain. Sand it with a finer sand paper, and stain again which can allow you to get some really interesting dual color results as the stain from the first coat will stay in the softer grain.
I've also read a bit about but have no experience using dyes instead of stain. The water based analine dye sounds a little better for color retention, but I've had bad experience using water based stains with oil based finishes. I always use wipe on poly for a finish coat because it's so easy to get good results with, but the only stuff I have on hand now is oil based.
So, that's where I'm at and am wondering if anyone here has any suggestions or comments. The wife usually likes lighter colors so a straight up finish with no color added might be the way to go but when we were looking at flooring options I didn't care for the really light colored maple. I'm thinking a light golden brown would be the way to go, the piece we picked out has some really nice grain patterns in it that I would like to make pop.
ChadPMIK is offline
post #2 of 3 (permalink) Old 08-09-2013, 10:56 AM
Chad; you didn't really explain exactly what kind of stain you've been using. Is it a gel, or fairly heavy bodied wiping stain?
Personally I stick with Mohawk's very thin bodied product, and dilute it for a very light barely discernible effect. That has the effect of bringing out the grain without darkening the overall wood colour. Take a few scraps of the maple with you when you go to buy the stain.
Stains - Mohawk Finishing
DaninVan is online now
post #3 of 3 (permalink) Old 08-09-2013, 02:02 PM Thread Starter
First Name: Chad
I haven't decided what kind of stain to use yet, that's why I started the thread. The stuff I have on the shelf now is just your basic Minwax stuff.
ChadPMIK is offline
Utilizing Rit Dye for Lettering OutoftheWoodwork Sign Making 24 11-01-2017 08:39 PM
Finishing the way I see it! by Derek Willis. derek willis Woodworking Articles 0 02-28-2011 08:44 AM
Rail Stile / Ply Panel gluing / finishing steps? Nickbee The Finishing Touch 10 12-12-2007 10:22 AM
Finishing for a sign harrysin The Finishing Touch 4 11-15-2007 02:02 PM
What about finishing exotic woods? Mike The Finishing Touch 9 03-24-2007 07:11 PM
