Attach mirror to wood - Router Forums
post #1 of 9 (permalink) Old 08-30-2013, 01:27 PM Thread Starter
First Name: David
Default Attach mirror to wood
I make jewelry boxes for my nieces that have a small mirror attached to the inside of the top. I have used two sided tape. This does not always hold. Any suggestions for a better adhesion.
jdnordstrom2 is offline
post #2 of 9 (permalink) Old 08-30-2013, 04:13 PM
JCJCJC's Avatar
Country: Ireland
Whatever you stick to the back of the mirror is really only holding on to the paint protecting the silvering of the mirror. In addition, over time you run the risk of chemical reaction between the adhesive and the paint and silvering, which would become visible from the face of the mirror. Because it's a lid of a box, it will be opened and shut regularly - all of which will shock the mirror free from any adhesive over time. To really solve this thoroughly, consider redesigning your lids so that some sort of framing or even metal corners will hold the mirror mechanically, or else drill the mirror if you can and put screws and nylon washers in it, like a bathroom mirror.
jc
JCJCJC is offline
post #3 of 9 (permalink) Old 08-30-2013, 05:16 PM
John is correct about the silicone (and probably other adhesives) showing through. I used a silicone made for gluing mirrors and it is showing through after about 15 or so years. I only used the silicone in a serpentine bead, if you put it in a solid layer behind it it might not matter. There are clips made for holding glass and mirrors and they are fairly cheap. But I think the nicest looking solution would be to hold them in with a wooden frame.
post #4 of 9 (permalink) Old 08-30-2013, 07:48 PM
JOAT's Avatar
First Name: Theo
Epoxy is supposed to work well. But I go along with John and Charles on this.
JOAT is online now
post #5 of 9 (permalink) Old 08-31-2013, 09:08 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
This pdf shows how I mount a mirror in the lid of jewellery boxes.
Harry
harrysin is offline
post #6 of 9 (permalink) Old 09-02-2013, 04:44 AM
JOAT's Avatar
First Name: Theo
You do some really nice work Harry.
JOAT is online now
post #7 of 9 (permalink) Old 09-02-2013, 05:31 AM
harrysin's Avatar
First Name: Harry
Thank you kind sir!
Harry
harrysin is offline
post #8 of 9 (permalink) Old 09-02-2013, 06:27 AM
First Name: del
very nice looking jewelry box , i see you used weld-wood glue, i use that sometime's very good dry's fast, i guess that glue was orignal use for landow car top's ?? that is what i was told ,, any way good pdf also thanks del
del schisler
port st. lucie, florida
del schisler is offline
post #9 of 9 (permalink) Old 09-02-2013, 07:32 AM
harrysin's Avatar
First Name: Harry
It really is a great glue Del., a lap joint will stay intact and the surrounding wood will break plus it dries transparent and doesn't leave a water mark like the yellow Aliphatic resins and as you said, it goes off really fast, many jobs can continue after about half an hour.
Harry
harrysin is offline
Wood Species dattashri Wood Species 7 07-26-2012 10:23 AM
Exterior wood Treatment dattashri The Finishing Touch 3 05-14-2012 11:37 AM
Attaching Patterns To Wood Vector01 Wood Scrolling 4 10-18-2011 01:50 AM
Best Places to buy wood? big wes New Member Introductions 12 01-26-2010 04:34 PM
