Too many paint types - Router Forums
post #1 of 4 (permalink) Old 04-11-2014, 08:24 PM Thread Starter
First Name: Don
Default Too many paint types
So I am getting close to finishing my bookshelves & the wife wants them painted. I have sprayed latex but was looking for something more durable. I have been reading up on waterborne enamel when I came across catalyzed lacquer then found conversion varnish. I am looking for one that will be durable yet kinda foolproof in painting. I have an hvlp gun that I will be using. Thanks in advance
Making sawdust & scraps all at the same time
Salty Dawg is offline
post #2 of 4 (permalink) Old 04-12-2014, 07:38 AM
First Name: Richard
Send a message via Skype™ to rwbaker
Use a sanding sealer so any water based paint will not raise the grain, the latex and several coats of General Semi-gloss or Gloss polyurethane. I used a very cheap HP sprayer last time and it turned out beautiful. I have also used the General product with a foam brush with the same result.
Good luck - Baker
rwbaker is offline
post #3 of 4 (permalink) Old 04-19-2014, 10:40 AM
I think you are over thinking things. I believe you are looking at automotive paint. Sherwin Williams should have anything you need. Or if it is wood, go with a polyurethane.
papercut is offline
post #4 of 4 (permalink) Old 04-19-2014, 08:34 PM Thread Starter
First Name: Don
Thanks for the help. Going with General Finishes milk paint use their poly acrylic as a top coat. Wife like their lamp black color.
Auto Paint? tonycar Sign Making 10 06-30-2014 06:47 PM
Paint over paint The Warthog The Finishing Touch 3 09-29-2011 12:55 AM
My Step-Back Cupboard Build rwyoung Project Plans and How To 53 11-13-2010 10:22 AM
Thinning out paint to soak in wood StormStrikes The Finishing Touch 3 08-18-2010 10:59 PM
