House humidity for wood - Router Forums
post #1 of 5 (permalink) Old 05-01-2014, 05:07 PM Thread Starter
First Name: Peter
Default House humidity for wood
I have some white oak that I will be using to create some stave drums and it's the first time I've done anything with hardwood. My house is fairly humid (approx 70%). Should I lower this (buy a humidifier) or is this ok? The drums are for my personal use so it will be also be stored with approx 70% humidity.
I've only had the wood a few days and the moisture content is 2-4%. It was kiln dried.
What should I expect the wood to do in my house? Will the moisture content gradually increase until it stabilizes and then I can start working on it once it has settled? Any ideas what the moisture content will reach?
DrillingThrough is offline
post #2 of 5 (permalink) Old 05-01-2014, 08:41 PM
Semipro's Avatar
First Name: John_*
Peter
You should be fine ,just let the wood acclimate to the surroundings that it will be used in, it should not be a problem
By the way you need a dehumidifier
Semipro is offline
post #3 of 5 (permalink) Old 05-01-2014, 09:16 PM
I agree with John. Let it acclimate first. Keep checking the MC until it has stabilized.
The acceptable moisture levels in a house range from 30% RH to 70% RH. At either extreme, health problems can begin to occur. At the higher extreme, mold can start to grow. If the average humidity in your house is 70% then the RH in your bathroom and kitchen are probably higher and your bedroom may be higher by morning each night. I would look at ways to try and get it down at least 10%. If the outside humidity is lower then some ventilation will help.
post #4 of 5 (permalink) Old 05-02-2014, 11:03 AM
rwl7532's Avatar
First Name: Ralph
Join ghostnote.net (drum builders forum) and ask your question there.
  • Accident free since 10/27/12 at 3:58 pm.
  • Cursing free since 10/27/12 at 3:59 pm.
  • ...it happened in Everett, WA USA
rwl7532 is offline
post #5 of 5 (permalink) Old 05-02-2014, 11:46 AM Thread Starter
First Name: Peter
Thanks for the info. It turns out that my humidity is actually around 50%. I got a new meter and the old one must have been too old. I got a dehumidifier anyway though as I do get a bit of mold around one window in the winter.
Free Doll House DXF pattern makecnc CNC Routing 36 11-25-2018 01:21 AM
Beach House Signs chief5130 Show N' Tell 19 06-18-2013 09:06 AM
House blew up! jd99 Lobby 4 10-02-2009 07:14 PM
