Sanding Sealer - Router Forums
post #1 of 10 (permalink) Old 07-15-2014, 12:59 AM Thread Starter
First Name: Rob
Default Sanding Sealer
Can you use Water based Polyurethane as a sanding sealer and then paint with common spray paint. (RustOleum) what problems will you run into?
Rob Allgood is offline
post #2 of 10 (permalink) Old 07-15-2014, 03:44 AM
old55's Avatar
First Name: Ross
Welcome to the forum Rob.
Ross,
old55 is online now
post #3 of 10 (permalink) Old 07-15-2014, 07:15 AM
Hey, Rob;
just out of curiosity, I checked out MOHAWK's waterbourne sanding sealer. Here's the contents...scroll down a bit for the ingredients.
Seems like it's basically acrylic resin, not polyurethane.
http://www.mohawk-finishing.com/mhk_...MA640-1067.pdf
How about just using an acrylic sealer?
DaninVan is offline
post #4 of 10 (permalink) Old 07-15-2014, 12:25 PM
Semipro's Avatar
First Name: John_*
Hey Rob, it's great to meet you and have you as a member of our community, welcome!
Thank You John
Semipro is online now
post #5 of 10 (permalink) Old 07-15-2014, 09:22 PM
smitty10101's Avatar
First Name: smitty
Send a message via Yahoo to smitty10101
Why not just use
#1 dewaxed shellac either spray or brush on
or
#2 primer that's sand-able again either spray or brush/roller applied
smitty10101 is offline
post #6 of 10 (permalink) Old 11-02-2014, 03:15 AM
First Name: jimmy
Send a message via Yahoo to bowdean
Rob,over the years have found that you can use finish such as lac. And poly. For sealers.only problem they dont have sanding agent in them,will seal wood ok, but wont sand as easy . Never had good luck with water base finish, always raised grain of wood more than i liked it to.later bowdean---are we having fun yet?
bowdean is offline
post #7 of 10 (permalink) Old 11-02-2014, 10:15 AM
Urethanes don't usually sand very well and tend to plug up sandpaper pretty quick. Regular sanding sealer is pretty cheap so why not use it?
post #8 of 10 (permalink) Old 11-02-2014, 12:56 PM
MAFoElffen's Avatar
Note on how to use shellac as sanding sealer...
When you mix shellac for sanding sealer, it's very much thinned down with denatured alcohol. <-- Not at it's usual mix. The goal is for it to soak into the wood and be sucked up by it, and it dries below the surface... Until it just before it won't soak in the the surface any more. That takes some practice at that to get that right.
When you have done that (below the surface) then it will take stain evenly. If a paint out, then you don't worry that it will no longer soak anything into it... and can go hog-wild. With it thinned down so much, it is easy to sand away any excess and really doesn't load up on sand paper.
(IMHO)
If you already buy shellac flake and already have it on-hand... Mixing it thin is cheaper and one less trip to the stores to buy just sanding sealer. What I've noticed about store-bought sanding sealer, is that most seem to be a sort of cellulose affair, that fills the open pores to make it smooth at the surface... and when sanded, it doesn't seem to take stain in itself like I want it too. For paint-outs, I've used thinned down wood-filler or thinned down wood glue to do the same. If you are just doing a paint-out, any primer will work.
MAFoElffen is offline
post #9 of 10 (permalink) Old 11-04-2014, 03:25 PM
RJM60's Avatar
First Name: Robert
Default Walnut ??
So if I want to finish some walnut with BLO and then shellac, would the finish order be BLO, Sealer, Shellac?
Thanks,
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #10 of 10 (permalink) Old 11-05-2014, 12:06 AM
boogalee's Avatar
First Name: Al
Thanks,
Mix 1 part BLO, 1 part shellac, 1 part denatured alcohol and apply. You can apply multiple coats.
Al B
boogalee is online now
Cabot Sanding Sealer Marco The Finishing Touch 3 02-20-2013 10:26 PM
Sanding BernieW Woodturning and Lathes 9 12-29-2011 07:01 PM
Finishing the way I see it! by Derek Willis. derek willis Woodworking Articles 0 02-28-2011 08:44 AM
Sanding sealer ? dwayne423 Lobby 15 12-16-2009 03:33 AM
Sanding Sealer - What is it? Thrifty Tool Guy The Finishing Touch 11 02-21-2009 08:28 AM
