Make an old wood floor look a bit better??? - Router Forums
post #1 of 12 (permalink) Old 11-15-2014, 09:25 PM Thread Starter
JudgeMike's Avatar
Default Make an old wood floor look a bit better???
Hi All,
Hoping someone can suggest an easy roll on application to seal and make an old scratched up floor look a bit better. It is a rental and I do not wish to sand and refinish properly at this time. I just want to make it look a bit better than it is. I believe the wood to be southern pine. It is a softer type wood. It is a darker color now with many scratches and places which the color is just plain wore off. If I could roll on some kind of stain/Polyurethane mixture I would be happy if something like that would work. Any ideas?? Also would like to use the same on the window sills to refresh/seal them. Attached are a few pictures of the floors and window sills. The small Victorian home was built about 1903. Again, just looking for a quick fix that will be a bit better than what I have. Thanks for any advice...Mike
JudgeMike is offline
post #2 of 12 (permalink) Old 11-15-2014, 10:44 PM
Semipro's Avatar
First Name: John_*
The only thing I can think of just clean well, stain over the top dry and re seal.
I am sure you know the only proper way sand stain and seal,but I have over stained and made them look better.
Semipro is offline
post #3 of 12 (permalink) Old 11-16-2014, 06:43 AM Thread Starter
JudgeMike's Avatar
Thanks John,
I have sanded, stained and sealed other properties. (should say I have HAD it done) and it looked beautiful when done. This time, for now, I just need a quick fix. Can you possibly give me the brand name of a stain and sealer you would recommend? Is there one product that has both stain and sealer combined for floors? I would most likely be buying at Menards, but other stores available too. Thanks again for your time and help. I never did have much talent in the finishing dept., unless it just needed painting or a good cleaning. :-) mike
post #4 of 12 (permalink) Old 11-16-2014, 07:17 AM
First Name: Dennis
I've used Minnwax from Home Depot that is stain and poly together to make old door slabs look a lot better . They do turn out pretty decent but they were a lighter color and I went slightly darker. You could put a coat of floor poly on over it if you wanted.
Dennis
Tough as nails and nearly as smart
Good tools don't cost- they pay!
64 ford is offline
post #5 of 12 (permalink) Old 11-16-2014, 08:08 AM
TwoSkies57's Avatar
Hey Judge...
Home Depot carries a product that is a quick fix for refinishing floors. I looked into it not to long ago. Renewit, restoreit...something like that (I can't for the life of me recall the exact name)..Everything I read pretty much said its a pretty decent product. Not a long term fix, but great for quick new look. I plan on using it on my hardwood floors..
This isn't the product I was thinking of, but very similar if not the same stuff in a different bottle..
http://www.homedepot.com/p/ZEP-32-oz...FR32/202218286
Here we go.. this is what I was thinking of
http://www.homedepot.com/p/Rejuvenat...2?N=5yc1vZba6w
Skipper the Penguin
TwoSkies57 is offline
post #6 of 12 (permalink) Old 11-16-2014, 11:46 AM
I haven't used this product, but it claims you can go over the existing finish. Might have to do a light sanding to get it to hold.
Minwax PolyShades - Oil-Based Stain & Polyurethane Finish | Minwax
Good luck,
Herb Stoops is online now
post #7 of 12 (permalink) Old 11-16-2014, 12:21 PM
Mike; whatever you use you first need to lift any residual waxes (remember that a lot of wax type products also contain Silicone!) Talk to a janitorial supply house for professional floor cleaners. Don't even contemplate putting something else down before the existing is chemically clean; you will end up sanding!
DaninVan is online now
post #8 of 12 (permalink) Old 11-16-2014, 12:27 PM
TwoSkies57's Avatar
Dan,, what about the two products I linked above? They pretty much say to just wipe on?
Skipper the Penguin
post #9 of 12 (permalink) Old 11-18-2014, 02:24 PM Thread Starter
JudgeMike's Avatar
Thanks for all your input. Guess I will use some stain to match as best as I can then Poly after that. Again, thanks for the ideas! Mike
post #10 of 12 (permalink) Old 11-18-2014, 02:40 PM
Bill; let the buyer beware, eh?
That's a lot of work to go to and then find out that there was indeed a problem.
Nothing sticks to silicone...or at least not for very long (well maybe doggy doo-doo, but I'll let someone else do the research )
Ready to learn bretneygibson New Member Introductions 11 11-11-2014 07:04 AM
New to wood working and using a router. Daveagle New Member Introductions 7 11-05-2014 09:35 AM
3/4in Depth cut rabbeting bit Rell Router Bits - Types and Usage 5 01-20-2012 11:16 AM
How To Make a Box with a Box Joint learnexperience General Routing 7 08-07-2011 07:07 AM
