Finish for shop made jigs - Router Forums
 1Likes
  • 1 Post By RMIGHTY1
post #1 of 6 (permalink) Old 03-26-2015, 10:23 PM Thread Starter
Default Finish for shop made jigs
Can anyone recommend the best was to finish shop made wooden jigs?
I am making a router fence, the sub base parts are maple and alder. Sliding front fence is UHMW. Should I use spray varnish on the wood followed by paste wax? Another idea I had was to use Bri-wax on the wood. Any suggestions or recommendations?
dmfotoman is offline
post #2 of 6 (permalink) Old 03-26-2015, 11:03 PM
First Name: Ray
I would use sanding sealer (wax free shellac), especially if maple is a softwood maple, followed by at least 2 coats polyurethane. Johnson's Paste Wax for sliding surfaces. Nothing on UHMW surface.
I use:
http://www.homedepot.com/p/Zinsser-1...0MgaAt9T8P8HAQ
and
http://www.homedepot.com/p/SC-Johnso...0203/100154748
I do NOT use tung or linseed oil as I feel that is too soft a finish and will not protect from shop stains.
Cheers!!!
RStaron likes this.
Copyright©2015 A.D. (Anno Domini, Latin for "in the year of our Lord") e.g., historical FACT!
Life is a comedy for those who think, but a tragedy for those who feel.
Let your smile change the world. Don’t let the world change your smile.
RMIGHTY1 is offline
post #3 of 6 (permalink) Old 03-27-2015, 08:00 AM
You just want to seal the wood to keep it stable I would say. The best finishes for resisting moisture are (least to best) water based varnish, oil based varnish, marine spar varnish, and epoxy.
post #4 of 6 (permalink) Old 03-27-2015, 10:05 AM
PhilBa's Avatar
First Name: phil
I can't remember where I heard this (one of the online wood blogger guys) but you should use shop made jigs as an opportunity to try different finishes and techniques.
PhilBa is offline
post #5 of 6 (permalink) Old 03-27-2015, 12:26 PM
phillipsted's Avatar
First Name: Ted
I would also recommend finishing all sides of each piece of wood. This way you don't get any racking because of differential exposure to humidity...
I'd also recommend going with a poly top coat.
TedP
phillipsted is offline
post #6 of 6 (permalink) Old 03-27-2015, 07:01 PM
RStaron's Avatar
First Name: Ron
I would use a rub on satin poly. this soaks in the wood and there is no build up of
finnish.
A person can never have too many tools!
RStaron is offline
Finish for spoons Guarnera The Finishing Touch 8 11-11-2013 03:50 PM
Oak Park spacer (box) jigs jw2170 Jigs and Fixtures 9 07-29-2013 09:08 PM
jigs from aluminum? meanbee Jigs and Fixtures 13 01-22-2013 06:31 AM
What is the white material all your jigs and fences are made of? paulcomi Jigs and Fixtures 16 05-19-2006 11:05 AM
What jigs do you find most useful? paulcomi Jigs and Fixtures 15 10-10-2004 10:09 PM
